MAP sensor ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-24-2009, 03:41 AM Thread Starter
oilfield trucker
zpilgeram's Avatar
MAP sensor ?
My trucks cuts out when it get up around 2800 rpm in forth and fifth gear. I have been thinking it was a fuel delivery issue which I still think it is. But lately I 've been watchin my boost gauge and have noticed that it doesnt seem to matter where my rpm's are, when my gauge hits 14lbs of boost the truck cuts out and the needle drops and the truck takes off agian. If I leave it on the floor it will just keep doing this, lurching down the hiway.After thinking my problem was the MAP sensor I wrapped my truck up in third gear to about 3200rpm and got my boost up to 14lbs and it did it again. Anyone ever heard of this ? Is it even possible for the MAP sensor to cause this problem ? Thanks
zpilgeram is offline
post #2 of 5 (permalink) Old 06-24-2009, 07:24 AM
Terminator Nation
Re: MAP sensor ?
Unplug the map sensor so the computer runs in the default mode for MAP input. If it doesn't cut out at 14 psi then the MAP is bad.
old man dave is offline
post #3 of 5 (permalink) Old 06-24-2009, 10:40 PM Thread Starter
oilfield trucker
zpilgeram's Avatar
Re: MAP sensor ?
Great I'' try that and see what happens. Thanks
post #4 of 5 (permalink) Old 06-24-2009, 11:13 PM Thread Starter
oilfield trucker
zpilgeram's Avatar
Re: MAP sensor ?
Well I just came in from trying that and thats what the problem was. The MAP sensor must be bad. Thanks for telling me to unhook it and drive it like that. It just goes to show you what a benefit it is having boost, and egt gauges. I would have never figured it out if I did'nt have my gauges. Well that and just the fact that I'm a frikin awesome diagnoser of problems.
post #5 of 5 (permalink) Old 06-25-2009, 12:25 AM
Kid with a Wrench
AlaskaRedneK's Avatar
Send a message via MSN to AlaskaRedneK
Re: MAP sensor ?
you will have a pm
-matt
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, Fresh Engine, Stacks, 7 Gauges, AFE, e-fan, BIG Kustom fuel system, 250cc
Hybrids w/ 100%s, H2E, 3" intakes, Bad Boy
Tranny built by me, ARPs, 910s, P-rods, 17*, SD IC
AlaskaRedneK is offline
