truck not running after injector swap. please help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 06-23-2009, 03:50 AM Thread Starter
just changed stock injectors out to stage 1s. took forever for the truck to start, now the only way it will run is if u hold it on the floor board and it still barely runs. it is pushing alot of air back to the tank, enuf to make a hissing sound out of the fuel cap. then it tripped the check engine light... please help
mcdad1979 is offline
post #2 of 12 (permalink) Old 06-23-2009, 04:13 AM
Early bird gets the worm
95dieselsmoke's Avatar
Re: truck not running after injector swap. please help
Did you purge the cylinders of all oil?
95 F250
Dana 60 swap
9" lift/40x13.5x20 ProComps
ZF5 swap/short throw/SouthBend CON OFE
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
autometer pyro,boost
6" black miters
95dieselsmoke is offline
post #3 of 12 (permalink) Old 06-23-2009, 04:14 AM Thread Starter
installed the injectors then took all glow plugs out and cranked it over. then reinstalled glow plugs and tried to start.
post #4 of 12 (permalink) Old 06-23-2009, 04:19 AM
Taking forever to start the truck after the swap is normal... It will take a while for all of the air to leave the system. Does it idle at least? I would let it run for a bit and see if it gets better as air works its way out. Not sure on the CEL, Do you have access to a scanner?
95 F250
Dana 60 swap
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
6" black miters
post #5 of 12 (permalink) Old 06-23-2009, 04:25 AM Thread Starter
the truck wont idle on its own... could it be that my hpop is to wore out or that i need to pull the galley plugs and crank it till oil comes out of them?
post #6 of 12 (permalink) Old 06-23-2009, 02:51 PM
Cratos's Avatar
When I did mine before I started it and the glow plugs where still out I cranked it 5 or so times for 20 sec or so in till I had 20 psi oil pressure ( I have my oil pressure gauge mounted on the HPOP res)
That got most of the air out of the heads before I started it.
But if you have excess air in your system that you are hearing air escaping I wonder if you messed up one of the o-rings? What is your fuel pressure like?
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #7 of 12 (permalink) Old 06-23-2009, 05:24 PM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
If it's hissing air out the fuel cap, than there's likely an o-ring cut or an injector not seated all the way.
How did you make sure you had the injectors seated?
You need a scanner to see what code or codes you've got.
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #8 of 12 (permalink) Old 06-23-2009, 05:27 PM
Dairy Mechanic
Magnum PD's Avatar
Too bad you don't a have HPO gauge.
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #9 of 12 (permalink) Old 06-23-2009, 06:30 PM
greenbeast's Avatar
Tighnen your injectors down again.
greenbeast is offline
post #10 of 12 (permalink) Old 06-23-2009, 06:37 PM Thread Starter
well we narrowed it dwn to it being 1 of the drivers side injectors seeing how we put the stock ones back inthe passenger side. Jim says one of the injectors probably has a broken internal part letting that cylinder pressurize the fuel system. injectors have new o rings on them
