Injector life - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 06-22-2009, 03:15 AM Thread Starter
gnxtc2's Avatar
Injector life
Any idea of the life expency of an OBS injector? Meaning average mileage for some type of injector work ie. o-rings or rebuild.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #2 of 13 (permalink) Old 06-22-2009, 04:16 AM
matthewd11's Avatar
Re: Injector life
250,000 +/- miles depending on maitenence.
matthewd11 is offline
post #3 of 13 (permalink) Old 06-22-2009, 04:28 AM
Early bird gets the worm
95dieselsmoke's Avatar
Re: Injector life
My orings were shot/replaced at 175,000. Rebuilt at 230,000.
95 F250
Dana 60 swap
9" lift/40x13.5x20 ProComps
ZF5 swap/short throw/SouthBend CON OFE
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
autometer pyro,boost
6" black miters
95dieselsmoke is offline
post #4 of 13 (permalink) Old 06-22-2009, 07:47 AM
Clay
fatboy95's Avatar
Re: Injector life
# 5 and # 8 finally went out at the dealer just those two are 375 each I ordered baby swamps from swamps diesel for 1100 shipped and chip for 400.00 call David at swamps he will treat you right
95 ext 4x4
with fat guy driving
fatboy95 is offline
post #5 of 13 (permalink) Old 06-24-2009, 09:58 PM
ADubDiesel's Avatar
Re: Injector life
Whoa, you guys are getting a lot more out of yours than I expected. I think my injectors are shot at 99k. I need to look into my rough start up a little more then...
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #6 of 13 (permalink) Old 06-24-2009, 10:30 PM
The Original
BigStroker's Avatar
Re: Injector life
what kind of rough start?
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #7 of 13 (permalink) Old 06-26-2009, 09:38 PM
ADubDiesel's Avatar
Re: Injector life
The idle is inconsistent for a 5-10 seconds then flatens out. Maybe rough start isn't the right term?
post #8 of 13 (permalink) Old 06-27-2009, 05:05 PM
matthewd11's Avatar
Re: Injector life
Sounds more ICP related.
post #9 of 13 (permalink) Old 06-27-2009, 05:05 PM
spock1996's Avatar
Re: Injector life
my 99 was doing that some and i had 2 glow plugs bad and would idle ruff till it warmed up a bit when it was cold out, my 97 wouldnt start when it was 70 out and smoked out a block when it did start had 2xx,xxx miles and all glow plugs were good, harness were good, and relay was good i think it needed injectors.
99 1/4 F-350 7.3L, 4" Dp, Dual 5" Exhaust, Van Turbo, K&N, PHP FU 6-chip, DIY Gen3 HPOS, My Own Fuel Filter/Return, Built Auto Trans with PI Stallion Converter, Detroit True-Trac Rear, 2003 Dana-60 Front, Traction Bars, Gauges, Ford Racing Speed Recalibrator.
spock1996 is offline
post #10 of 13 (permalink) Old 06-27-2009, 06:49 PM
ADubDiesel's Avatar
Re: Injector life
Well I got the truck in April. One morning it got down in to the 30's and it took like 6 tries to finally get it started. It's been warm since so it's started every time since. I just want my truck to start come fall. When you say ICP, what would that involve? I hope it's just glow plugs. Planning on doing those before it gets cold just as a precaution.
