4wd Shift Maintenance and Mod! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-22-2009, 01:43 AM Thread Starter
Well after I blew my tranny a few weeks I tried to put my truck in 4wd to see if it would move. It wouldn't so I tried to put the t-case in neutral to tow it and low and behold it wouldn't go cause it wouldn't push down. As I was swapping transmissions I looked and in the last 3 years I have owned the truck one of the boots was melted from the previous owner and just now seized.
Well since the shifter is only available from Ford for around $250 as a unit and no parts sold separately I knew I wasn't going that route.
So I decided a bicycle inner tube would work well for a rubber boot and that two grease zerks needed to be installed to prevent any further failures to operate. So here is what it looks like. The only change i made to it was to put a 90 degree zerk in the mounting bolt pivot.
tjbeggs is offline
post #2 of 4 (permalink) Old 06-22-2009, 02:19 AM
GoNavy!
DcMoore999's Avatar
Re: 4wd Shift Maintenance and Mod!
Looks nice man, think I'll steal your idea
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #3 of 4 (permalink) Old 06-24-2009, 02:44 PM
Did you drill and tap for the zerks? I haven't looked at mine yet it's just a PITA to shift. Good thing the trucks weight keeps me on road ATM.
Dave
1994.5 F350
4x4 with 285/75R16
5 Speed Manual
4.11 Gears
DIY Intake
Downpipe, Straight Exhaust
1st Year Stroke still going at 287K
ghostang93 is offline
post #4 of 4 (permalink) Old 06-25-2009, 02:52 AM Thread Starter
Dave
Yes drilled and tapped. 1/4-28 threads for the zerks I had. I think those threads required a #3 drill bit.
tjbeggs is offline
