AC issues.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-21-2009, 04:30 AM Thread Starter
PSN nerd
AC issues....
my ac is back to cycling on and off. i thought it was the connector on the low pressure switch on the compressor so i bypassed it and its still cycling. i checked a couple things like one of the ac guys at work said to check refrigerant levels and from the results of that he said there is still the right amount of refrigerant in it. so i think its tripping out on the high pressure switch. whats causing it to do this is the expansion orfice getting full of junk? is my compressor fixing to die on me? when it is blowing cold it blows very very cold when i did the checks on the ref. levels the outlet temp was 38deg so i dont know.....
thanks!
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #2 of 5 (permalink) Old 06-21-2009, 06:36 AM
What else?
smokyred's Avatar
Re: AC issues....
You need to put a set of gauges on it, then tell us what the pressures are and what they're doing. That's where you start with AC.
Dave
smokyred is offline
post #3 of 5 (permalink) Old 06-21-2009, 07:58 AM
gracing's Avatar
Re: AC issues....
Like stated above, put a set of gauges on it and check your low and hi side pressures. Does it only do it at idle? If you have a hi side pressure problem at idle your fan clutch could be bad.
gracing is offline
post #4 of 5 (permalink) Old 06-21-2009, 01:43 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Re: AC issues....
Listen to Charles- He is correct. Start with pressures. That will allow you to see what is happening. You will be able to watch the components work and go from there. Is there dye in it? If so, look for traces at compressor, clutch, switches lines/line connections, in evaporator box or coming out the drain.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #5 of 5 (permalink) Old 06-21-2009, 03:25 PM Thread Starter
PSN nerd
Re: AC issues....
ill get a set of gauges from work tommorrow, just hope they have the fittings to hook up to the truck. i have never worked on the ac charge so if theres not dye from factory theres not dye in it.
thanks guys !!
JAKE is offline
