steerin gear box - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-19-2009, 04:06 AM Thread Starter
deiter5262's Avatar
steerin gear box
Hey fellas, my 97 7.3L 4x4 HD 214k miles on clock, has as much play in the steering wheels as an old farm tractor and I've rebuilt the entire front end all ball joints, tie rods, arms, front axle, pulled hubs apart complete rebuild and repacked wheel bearings,seals, you name it....Anyway, I can't figure out why she has soo much play in the steering wheel, starting to scare me...this is the last thing I've yet to replace will that fix it?
Also, every so often when turning onto an incline parking lot or hill (only when turning putting the truck off balance (one side higher than the other), I keep hearing a loud "Pop" noise like a spring pop out of place or something but i keep checking and nothing is out of the ordinary or loose that i can tell...do you think this is the shocks?
Thanks in advance for any help
Thinkin about headin up to local parts store and pickin up one tomorrow?
2008 F250 4x4 King Ranch 6.4 CC--SOLD
2000 SD F350 SRW 4x4 CC Lariat-, 5% tint-wkd whl, 1.0 hsg, EBPV md, Beans stg 2's sticks, Beans 6 pstn ,IDM MOD, DI Reg. Retrn, ITP bst anltr, 6637, CCV, MBRP 4 dp/exht, BTS VB, atmr tri-pillr~ 20X10 BMF's fresh paint!-SOLD
1997 F-250 4X4 CC SB 7.3L HDPS-- SOLD
deiter5262 is offline
post #2 of 7 (permalink) Old 06-19-2009, 04:45 AM
Don't EFN worry about it
Aljay's Avatar
Re: steerin gear box
There is a TSB for the pop ! Its a rivit on the frame . Replace the box .
Tuned by T Wildman
Aljay is offline
post #3 of 7 (permalink) Old 06-20-2009, 01:29 AM Thread Starter
deiter5262's Avatar
What is a TSB?
Anybody tell me what model number I need to buy for the steering gear box? Napa caries three different models for my truck in my sig??
post #4 of 7 (permalink) Old 06-20-2009, 06:15 AM
zilla68's Avatar
TSB is a technical service bulletin issued from ford for a known problem.
I am sure someone will know what the actual tsb was or google your problem and put tsb at the end and see what gives.
I do know this though, when I bought my steering box from napa, I took it off first, they wanted double the price in core charge, the guy told me they really want to make sure they get the cores back.
You might check AGR, I think they make really good steering boxes also.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #5 of 7 (permalink) Old 06-20-2009, 06:50 AM
travis162's Avatar
it sounds like your pitman arm is loose. you can check it by watching it while someone moves the steering wheel back and forth and make sure there's no play. if that's it torque that sucker back downand keep an eye on it if it comes loose again you will have to replace the out put shaft on your steering box but hey its alot cheeper than buying a new one
travis162 is offline
post #6 of 7 (permalink) Old 06-20-2009, 11:34 PM Thread Starter
deiter5262's Avatar
yeah, someone else told me that and i had a friend look at it while i turned the wheel and everything looked tight underneath?
post #7 of 7 (permalink) Old 06-20-2009, 11:37 PM Thread Starter
deiter5262's Avatar
I hear AGR and good but out the window expensive like 300-400 or so. I'm not going to waste that, I will just pick one up from NAPA for $160. Yeah,
I need to know what model number it is in order to order the right gear box in for my truck? They told me there is three different models for the same year, anyone know what number my truck would take (its in my sig)?
