ABS light flashing and shifter stuck in Park - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-18-2009, 03:48 AM Thread Starter
ianjadkins's Avatar
On the way to work this morning I stopped for a coffee and left the truck running. When I cam back I went to shift into drive and the shifter wouldn't move. I looked down and the ABS light was flashing. I shut it off, then started it to find the same. Luckly I had my blackberry so I googled (% Ford ABS light and found a forum about the same thing. The guy tried lots of stuff then someone told him to check his fuses and it was a fuse.
I did the same and it worked I changed the fuse, can't remember what one it was for off hand(top middle horizontal facing one)! The ABS flashed all the way to work, but on the way home it was gone.
Anyone ever hear of this? Know what causes it? Is there anything I should check or change to prevent it from happening again?
Thanks,
Ian
95 Extended cab Long Bed XLT
Dana 60
Tymar Intake
Sport Comp Gauges
FPR Shim
3" Dp - 4" Exhaust
ianjadkins is offline
post #2 of 5 (permalink) Old 06-18-2009, 02:15 PM
Re: ABS light flashing and shifter stuck in Park
Check the VSS sencer on top of the rear end. They get covered with fine shaves from the gears.
1997 F250 XLT CC 4X4 PSD E4OD 4.10LS (AB CALI TRUCK)
INTAKE
18K MOD
4"TURBO BACK DE EXHAUST
1705 SUPERCHIP
2" LEVELING
GAUGES
SONNAX VALVE WITH SPRINGS
TRANS COOLER
SWAMPS IDM
1996 F250 XLT EC 4X4 PSD E4OD 4.10LS
1705 SUPERCHIP
QUAD POD from Complete Performace
BD EXH BRAKE
3" DOWN PIPE
TRANS COOLER
DIY INTAKE
120v IDM
ono_55 is offline
post #3 of 5 (permalink) Old 06-19-2009, 05:43 AM
My '95 had a short in the trailer wiring and was causing the fuse to blow, fixed that and no more problems.
AZFairlane is offline
post #4 of 5 (permalink) Old 06-20-2009, 07:11 PM Thread Starter
ianjadkins's Avatar
Hmm, I wasn't hauling a trailer at the time but I have heard that a few other places now. I will have to look into it.
Thanks for the tips!
Dana 60
Tymar Intake
Sport Comp Gauges
FPR Shim
3" Dp - 4" Exhaust
post #5 of 5 (permalink) Old 06-21-2009, 01:45 AM
Heath
rollingthunder's Avatar
Mine did it last week. Post is further down on the page. Ended up being a short. THe brake on-off switch on the pedal. THe wires wrap around a piece of metal before going into the wire harness and melted the fuse. Not just blown--melted the plastic. I was all over the dash looking for it-theres alot of wire in there:)
2005 250 crewcab king ranch
arps, egr delete,coolant and oil bypass filters
4" turbo back MBRP
A-1000 fuel w\Reg return
Warrne 175\30's
rollingthunder is offline
