Dually front hubs ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-18-2009, 12:26 AM Thread Starter
ANIMOSITY's Avatar
Dually front hubs ?
Ive got a 92 f350 dually with a old diesel that I just picked up.
It is missing a bed and so I was thinking of just tossing the dually wheels. Just going with standard wheels, and picking up a cheap long bed. My question is, To do this does the front hubd just have spacers to accept the dually rims, or do I need to replace the whole hub? Thanks
For those who fought for it, Freedom has a taste the protected will never know!
ANIMOSITY is offline
post #2 of 4 (permalink) Old 06-18-2009, 01:23 PM
racehauler's Avatar
Re: Dually front hubs ?
You need to replace the whole hub that spins on the spindle.
Is this a 4X4? If so I have brand new Ford hubs for that application sitting at home that I decided not to use. Let me know if you are interested in them.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 4 (permalink) Old 06-19-2009, 01:33 AM Thread Starter
ANIMOSITY's Avatar
It is a 2wd.
post #4 of 4 (permalink) Old 06-20-2009, 04:55 PM
Michael's Avatar
If they stayed the same on my 1995, then it looks like the hub/rotor would be the difference. Check your local parts store for replacements, they may not be as much as you'd fear. I recently replaced mine due to heat cracks in the rotors. Hopefully the single-wheel versions would be cheaper.
Regards,
Michael Pliska
95 F350 CC DRW, ISSPRO Performax gauges, Diamond Eye 3x4" DP & 5" exh, MBRP tip, Baby Swamps & tunes, Trans VB mods, Dunrite TC, Lock-Right, Cal-Tracs
99 Silverado race truck
96 F250 RCLB, bone stock
00 Jetta TDI, Kerma Tunes, Der Chimera Stg 3 clutch
73 & 74 Vega race cars, 92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 Trans-Am 455
Michael is offline
