Left rear wheel HOT!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 06-17-2009, 12:49 AM Thread Starter
m-4
my left rear wheel is getting so hot i cant' even touch it. After driving for an hour. Also when on loose gravel the right rear wheel will spin but the left will not. I'm sure it's the drum but not sure
What is going on?
m-4 is offline
post #2 of 14 (permalink) Old 06-17-2009, 12:51 AM
jaybuller's Avatar
Re: Left rear wheel HOT!!!
yeah id say you got a brake shoe or caliper locked up i would take it off and free it with some wd40 and a big hammer. get it worked loose then get it workin. If it gets hot enough it gan ingnite the tar.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #3 of 14 (permalink) Old 06-17-2009, 12:54 AM
matthewd11's Avatar
Caliper/wheel cyl locked up. Have fun.
matthewd11 is offline
post #4 of 14 (permalink) Old 06-17-2009, 12:58 AM
Dairy Mechanic
Magnum PD's Avatar
I'm gonna say the brake "cable". My truck and brothers truck had the same problem. The cable is not letting loose all the way. Mine got hot after replacing the shoes. The old drum had a grove in it and the shoe was down to the metal all because the cable wasn't free. Only way for us was to replace the cable.
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #5 of 14 (permalink) Old 06-17-2009, 01:00 AM
matthewd11's Avatar
Well, that depends if he uses the cable..
It wont lock up unless he applies it and then wont release.
post #6 of 14 (permalink) Old 06-17-2009, 01:08 AM
Dairy Mechanic
Magnum PD's Avatar
Depends on how much tension is left on the cable when released. OP is gonna have to say what it's doing.
post #7 of 14 (permalink) Old 06-17-2009, 01:33 AM Thread Starter
m-4
yeah i use the cable my truck is a five speed.
what about the reeeaally spongy brakes and them being very sensitive?
m-4 is offline
post #8 of 14 (permalink) Old 06-17-2009, 01:35 AM
matthewd11's Avatar
spongy brakes sound like you got a leaky wheel cylinder/line. I'll bet you have a bad axle seal as well back there.
Does the pedal slowly sink to the floor sometimes?
I'll bet thats what froze everything up. I'd have it checked out as soon as possible. Seeing as you use your E brake often, i doubt that is your issue. They usually freeze up from lack of use.
post #9 of 14 (permalink) Old 06-17-2009, 01:59 AM
PSD
CNDiesel's Avatar
To free a stuck e brake and reset your brakes so they dont drag....
drive pritty fast in reverse and hit the brakes hard.
Doing that resets them. I use todo that when my ebrake would stay on.
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #10 of 14 (permalink) Old 06-18-2009, 02:16 PM
woodduck97's Avatar
That does work at times try it.
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
