removal of turbo... grrrrrrr - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-16-2009, 11:59 PM Thread Starter
how in the world do u get the lower 2 nuts off the turbo flange??? and the bolts off the up pipes to replace the donuts?
mcdad1979 is offline
post #2 of 7 (permalink) Old 06-17-2009, 12:02 AM
Don't EFN worry about it
Aljay's Avatar
Re: removal of turbo... grrrrrrr
You could drop the trans crossmember and drop it down some if you have a 4x4 drop the front drive line. Droping the trans down some makes it alot easier to get at some of the bolts.
Tuned by T Wildman
Aljay is offline
post #3 of 7 (permalink) Old 06-17-2009, 07:38 PM
Cratos's Avatar
the back to on the ped you need a 10 mm 1/4 drive with u joint, the two on the flang up top 1/2 drive or a box wrench and a braker bar. if you dont need the ebpv gut it while its off ,makes it easyer to do next time.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #4 of 7 (permalink) Old 06-18-2009, 06:46 PM
Stick of Dynamite..hate getting the stockers out! eayest is just pull the trans.
email:
Website:
OBSWIZ is offline
post #5 of 7 (permalink) Old 06-18-2009, 07:58 PM
Kid with a Wrench
AlaskaRedneK's Avatar
Send a message via MSN to AlaskaRedneK
I think you are asking about the bolts that mount the turbo to the collector? for the bottom right I use a short wrench and face offset towards the cab and use a hammer or something to hit it. For the bottom left I think I did something similar.
For the up pipe bolts you should be able to get up in there with a set of extenstions and a wobbley. To get that drivers side pipe out I had to remove the rear crossmember and lower the rear of the trans/t case to allow the pipe to come out from the bottom.
Matt
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, Fresh Engine, Stacks, 7 Gauges, AFE, e-fan, BIG Kustom fuel system, 250cc
Hybrids w/ 100%s, H2E, 3" intakes, Bad Boy
Tranny built by me, ARPs, 910s, P-rods, 17*, SD IC
AlaskaRedneK is offline
post #6 of 7 (permalink) Old 06-19-2009, 02:14 AM
Michael's Avatar
Here's how I got the lower nuts between the turbo and the collector housing:
I just heated & bent a 15mm box end wrench, cut it off, and welded on the cut-off end from a 3/8" drive extension. It worked great!
After much cussing, my eventual sequence of events was as follows:
1) Remove lower downpipe bolts from both sides (where they attach to the exhaust manifolds).
2) Remove turbo inlet hose and outlet Tee.
3) Remove downpipe clamp.
4) Remove EBPV housing (mine was already gutted so I didn't have to deal with the linkage rod). Definitely needed a 3/8" drive 12-pt 8mm socket for this one.
5) Remove all but the driver's side rear up-pipe to collector bolts, working from above initially with a box end wrench, eventually with a 1/4" drive socket.
6) remove top bolts and lower nuts connecting the turbo to the collector (using home-made wrench pictured above for the nuts).
7) wiggle the collector and up-pipes around, and push the collector back towards the firewall.
8) Use a 3/8" drive 10 mm swivel socket to remove the bolts holding the pedestal to the engine (you need to get to step #7 to allow the use of a 3/8" drive on the driver's side rear bolt).
9) Use a box end wrench to get at the last up-pipe to collector bolt.
10) Slide collector off of up-pipes.
Regards,
Michael Pliska
95 F350 CC DRW, ISSPRO Performax gauges, Diamond Eye 3x4" DP & 5" exh, MBRP tip, Baby Swamps & tunes, Trans VB mods, Dunrite TC, Lock-Right, Cal-Tracs
99 Silverado race truck
96 F250 RCLB, bone stock
00 Jetta TDI, Kerma Tunes, Der Chimera Stg 3 clutch
73 & 74 Vega race cars, 92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 Trans-Am 455
Michael is offline
post #7 of 7 (permalink) Old 06-19-2009, 04:21 AM
What else?
smokyred's Avatar
A shorty box wrench and a hammer gets those flange nuts loose or tightened.
PB Blaster helps alot also.
Dave
smokyred is offline
