Painting trim pannels - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-16-2009, 02:00 AM Thread Starter
Fire junkie
I need to replace my drivers door pannel, Haveing some trouble finding one in my color (Lt. gray) but I have found some in tan, and blue that are in good condition (found them at junk yards) is it worth it to try and paint them? I painted my A-piller gauge pod with paint from a auto body paint supplier and it came out ok, just did not know how a door pannel would hold up to use, (opening door, windows etc) any one do this and how has it held up? any other suggestions? thanks
stay safe out there
Roy
96 F250 C.C. , Rebuilt E4ODx2, open air intake, Hypermax downpipe,straight 4", Stage 1's, Autometer EGT, Boost, & Tran temp, Upgraded trannie cooler, Custom home built front & rear bumpers, head ache rack and 60 gal. Aux. fuel tank
Truck4 is offline
post #2 of 6 (permalink) Old 06-16-2009, 02:44 AM
ADubDiesel's Avatar
Re: Painting trim pannels
try craigslist for guys parting rigs out.
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #3 of 6 (permalink) Old 06-16-2009, 04:51 AM
Roy, I've seen folks here talk about painting their dash panels. At any rate, any paint job as you know is all in the prep.
If it we're me I'd follow a path of:
Clean well
Lightly scuff the panels with a 150-220 grit paper by hand (easy though or you'll have slick panels). A good bonding primer for plastics should suffice without sanding, providing you get them squeaky clean and dry.
Follow that with a couple of light fog coats of a good primer for plastics and then on to your top coats with long even quick strokes all the way through... end to end. Use a cross hatch pattern on successive coats.
IIRC, the folks I saw talking about it here used Krylon spray paints. IDK if that's what I'd use. Also IIRC, you can get some over priced paint made for just this purpose from the dealer.
Good luck - if you go this way, please post pics of the before and after.
'95 F250 Extended Cab E40D 2WD
IDM MOD - HPX -
dzlstroker is offline
post #4 of 6 (permalink) Old 06-16-2009, 05:02 AM
zilla68's Avatar
I posted a thread a few months back on how to make a single cab door panel work in a crew cab truck. Mine is still working out just fine, but I can't remember where I posted it at. check it out, it might help ya, or pm me and I can try and find it for ya, save yourself the headache and do a single or extended cab door panel.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #5 of 6 (permalink) Old 06-21-2009, 07:36 PM
Check out the video on panel painting here. The only negative is that you have to buy more dye than you will need
tycham is offline
post #6 of 6 (permalink) Old 06-21-2009, 07:49 PM
GoNavy!
DcMoore999's Avatar
http://www.paintscratch.com/ Try this site, they have all the colors hopefully you can find something on here.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
