White Smoke at start-up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-15-2009, 05:53 PM Thread Starter
kurtfromct's Avatar
got a 97 7.3 PSD with 139,000 miles not too long ago and was wondering what may be wrong and why the truck blows white smoke at start-up? what happens is i start the truck (it starts up fine) and there is a good size cloud of white smoke, then it continues to smoke pretty good for like 1-2 min, then there is just this faint white smoke that you can see if you look at the exhaust straight on. the truck sat for around 5 days, but it still does this even when the truck was ran the previous day (not quite as bad though). also, the truck could probly use an oil change, and it is stock. just curious whats wrong and what i should do? thanks guys
1997 F-350 7.3 POWER STROKE. XLT, 4X4, BLACK, REG CAB, STRAIGHT PIPED, DIAMOND PLATE TOOL BOX AND BED RAILS
SOLD
kurtfromct is offline
post #2 of 7 (permalink) Old 06-16-2009, 05:31 AM
Patrick Feeley's Avatar
Re: White Smoke at start-up
It sounds like you have glowplug system issues. Start with the glowplug relay. Measure the voltage drop (digital meter leads across the two large terminals on the relay) while the relay is energized (don't go by the wait-to-start light which has nothing to do with the actual state of the relay). Anyrhing more than a 0.5V drop and the relay is bad. If that shows as good then start looking at the glowplugs themselves. On each valvecover connector (there are two per valvecover, top edge front and back ... four total) the outermost pins are for the GP's (inner three are for the injectors). Measure the resistance from the GP pin to ground. Resistance should be from 0.1 to 6 ohms. If those check out good, then the batteries could be losing a bit or even the starter could be going (even though the starter can turn over the engine, just a bit slower can make a big difference! Cheers!
Patrick Feeley is offline
post #3 of 7 (permalink) Old 06-17-2009, 01:00 AM Thread Starter
kurtfromct's Avatar
wow, thats a good write-up, thanks a lot
SOLD
post #4 of 7 (permalink) Old 06-17-2009, 10:47 AM
Clay
fatboy95's Avatar
A good oil change and fuel filter change could not either
and uh
95 ext 4x4
with fat guy driving
fatboy95 is offline
post #5 of 7 (permalink) Old 06-17-2009, 08:44 PM
I would guess GP system. But I had the same problem with my 97 with 100k on it. Turned out to be injector o-rings. When your truck is warm and up to temp does it still smoke?
matt71 is offline
post #6 of 7 (permalink) Old 06-17-2009, 09:50 PM Thread Starter
kurtfromct's Avatar
not really, there is just a very faint haze, but the start-up is a cloud. it also seems to be a little rough starting considering its in the 70s outside and it was running the day before.
SOLD
post #7 of 7 (permalink) Old 06-18-2009, 12:06 AM
Start with your glowplug system and go from there. Im not sure but I believe when the engine is a certain temp. the glowplugs arent used to start it.
matt71 is offline
