windshield woes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-15-2009, 12:42 PM Thread Starter
F350 FF's Avatar
windshield woes
Hello all,
Whenever its rainy and dark out driving thru town it looks like there is a film on the inside of the windshield. I took windex and wiped it off, then a bit later it was back. I thaught I heard that a bad heater core will cause that as I can faintly smell coolant as well. Anyone know if thats the case or can lend any brainpower.
Thanks again,
matt z
Have - 95' F350 PSD, 2WD supercab dually, E4OD, 4:10's, Tymar intake, 3" DP, Bully Dog 4" cat back, CPR fuel bowl delete / E-Fuel, Adrenaline Oil
Want - ZF5, Flatbed
F350 FF is offline
post #2 of 5 (permalink) Old 06-15-2009, 02:20 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: windshield woes
Sounds about right.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #3 of 5 (permalink) Old 06-15-2009, 02:30 PM
Pulling sled for hire
ParkerFly's Avatar
Re: windshield woes
A bad heater core will cause the window to fog over, but it won't cause the film you're describing. That film is very common on most newer vehicles. Go to a parts store and get a good glass cleaner and use some old newpaper to clean your windshield. Either way, that film usually starts returning after a week or so, at least it does on all our vehicles.
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #4 of 5 (permalink) Old 06-15-2009, 04:54 PM
OEM Moderator
Tom S's Avatar
Re: windshield woes
I have had heater cores that would film up the windshield before. I think your is probably starting to leak.
Tom S is offline
post #5 of 5 (permalink) Old 06-16-2009, 02:16 PM Thread Starter
F350 FF's Avatar
Re: windshield woes
Thanks for the help fellas, unfortunatly it will be several months till i can do it as i am not at home at the moment. When i do get back i was gonn apull the motor replace my trans and do a bunch of wrk to now include the heater core. thanks again keep on truckin
matt z
Want - ZF5, Flatbed
F350 FF is offline
