Couple different turbo/up pipe questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 06-14-2009, 07:05 PM Thread Starter
Was PSD0389
Matt_P's Avatar
Ok so Ive got the trifecta going right now, my stock turbo is taking a dump (compressor wheel digging into housing) my pedistal o-rings are leaking and my up pipes are leaking
Anyways for a turbo Im gonna do a D-66 or another upgraded Drop in if someone has one comparable to a D-66 that will go well with my stage 2s.
I read a couple removal instructions, just wondering if anyone has any extra tips on removing it, also if anyone has instructions with pictures that would help since the ones I found didnt.
Then I know I need 2 sets of the o-rings.
Now for the up pipes, will the bellowed up pipes work on an OBS? If I remember correct they dont from what Ive heard but I wanted to check
Otherwise Ill just get new donuts, anyone have any good tips or pictures for replacing those?
Thanks again for the help
03 F-350 CCLB King ranch undergoing a 6.0 delete
99 Fummins- SOLD
95 F250- SOLD
08 6.4- Totaled 12/19/10
Matt_P is offline
post #2 of 24 (permalink) Old 06-14-2009, 08:53 PM
Re: Couple different turbo/up pipe questions
The 99+ up-pipes will NOT fit.
There are bellowed up-pipes available for our OBS styles. They are terribly expensive, over $900 at International. Try Boyers Custom Truck, they list them at a little under 9 bills.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air, Beans tunes on VA 4 position chip, Adrenaline HPOP, VDO boost/pyro/outside temp gauges, Ford digital AIC, DPPI downpipe, gutted EBPV, modded turbo ped, Con OFE, add-a-leafs front/rear, Monroe Reflex shocks, Milemarker 449SS hubs...coming soon: 6.0 IC...wish list: Stage 2's
nashvillebill is offline
post #3 of 24 (permalink) Old 06-14-2009, 09:37 PM Thread Starter
Was PSD0389
Matt_P's Avatar
Well in that case I wont be buying those, Ill just be replacing the donuts
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
post #4 of 24 (permalink) Old 06-15-2009, 01:22 AM Thread Starter
Was PSD0389
Matt_P's Avatar
bump
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
post #5 of 24 (permalink) Old 06-15-2009, 02:56 AM
Big_Dan97's Avatar
mod your pedestal :)
97 PSD 34
470hp/940tq, FFD, BDP, TW, RockinSPerf, Tymar, Stealth Oil, modded H2E, 230 cc a codes studs&springs, dual 4" exhaust, 7.3 IC, gauges, TC LU,TC/shiftkit, Family rig:02 7.3 Excursion tymar intake, 4"mbrp tb, evo 2
Big_Dan97 is offline
post #6 of 24 (permalink) Old 06-15-2009, 03:00 AM Thread Starter
Was PSD0389
Matt_P's Avatar
Thats a good point, I should definitley do that, how do I go about doing that? Do have a write up at all?
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
post #7 of 24 (permalink) Old 06-15-2009, 03:47 AM
Big_Dan97's Avatar
heres some pics of when I did mine
See where that arrow is? Thats where the ebpv solenoid sat, just unbolt that, then take some pliers and pull the shaft out that used to sit in there.
cut the barrel out as you see fit, once youre all done weld up any holes. Make sure your welder knows to ground out to the pedestal and not what the pedestal is sitting on or else the pedestal will arc to whatever its sitting on, and itll arc where the o-rings are supposed to go.
ebpv housing is easy, drill out the rivets in the "flapper" then the rod comes out and you can plug the hole with a freeze plug, carriage bolt, whatever you see fit. Make sure you clean out the pedestal.
97 PSD 34
post #8 of 24 (permalink) Old 06-15-2009, 06:45 AM Thread Starter
Was PSD0389
Matt_P's Avatar
Thanks for the pics man I appreciate it!
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
post #9 of 24 (permalink) Old 06-15-2009, 08:57 AM
Lovin the Tuna
RedSmokey's Avatar
a tip for turbo removal on any truck... PB Blaster. That stuff works wonders. Spray all the bolts on the clamps with PB blaster before you get started, ESPECIALLY if you havent had the turbo off before. I learned this the hard way
2001 F250
2000 F250
RedSmokey is offline
post #10 of 24 (permalink) Old 06-15-2009, 09:22 AM
Clay
fatboy95's Avatar
thanks for that question and answer saves me
fatboy95 is offline
