urgent help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-14-2009, 05:35 AM Thread Starter
single stacked stroker
yzdude250f's Avatar
urgent help
I was driving my truck today and pushed in the clutch in and the pedal hit the floor, the slave cylinder is ok and the master cylinder is fine as well, what has happened is the spline shaft the clutch pedal is on has stripped where the bracket goes to the master cylinder rod, can i find replacement parts also while the pedal box is out i plan on replacing the bushings, where can i get those as well.
2004 svt focus build # 1041
saving for another truck
97 f-350 SOLD
swamps 175's
2l destroyer 66 turbo
ts with custom tunes
southbend clutch
iss pro gauges
hpx cross over
Traction bars
For as fun as that truck was it was sure a piece of $h!t
Boosting 45psi on a stock charger ^
yzdude250f is offline
post #2 of 3 (permalink) Old 06-14-2009, 11:07 PM
Cratos's Avatar
Re: urgent help
check your pedle bushing when it brakes it will feel that way lost of slop in the peddle?
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #3 of 3 (permalink) Old 06-15-2009, 05:03 AM Thread Starter
yzdude250f's Avatar
Re: urgent help
Already replaced that before the splined shaft the the clutch pedal is attached stripped off.
97 f-350 SOLD
swamps 175's
southbend clutch
iss pro gauges
hpx cross over
Traction bars
