Manual to auto swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-13-2009, 10:22 AM Thread Starter
PSD
CNDiesel's Avatar
Manual to auto swap
Contemplating my options....
My clutch is going to need to be upgraded fairly soon, because of power reasons But the ZF5 isnt all that good anyways.... Grinds gears if you shift to fast, reverse is very frustrating to get engaged, And I like having a free hand to hold my food while driving.
How hard would it be to convert it over to a auto??
What will i need todo?
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #2 of 10 (permalink) Old 06-13-2009, 01:49 PM
PSN nerd
Re: Manual to auto swap
im working on the same thing.
ya need the shifter from an obs, and trans mount, transcooler, i think the best way to go about this is use the pcs controller then you dont need a auto computer and wire harness.
best bet is to find a 4r100 since it has the upgraded hard parts from the e40d. then you can swap the input shaft to the tcase or get an auto tcase. driveshafts will have to be reworked.
theres a thread goin in the trans conversion folder with the rest of the detailed stuff that i started that everyone else has chimed in on.
im just tired of my wore out 5speed and with no core i may as well swap it and with the pcs you can get push button shifting
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #3 of 10 (permalink) Old 06-13-2009, 02:03 PM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
Hopefully Charlie will see this thread and post up about his conversion...
I've debated the same thing in the past, but it would be a 4R100 instead of an E4OD going in.
PCS controlling everything.
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #4 of 10 (permalink) Old 06-14-2009, 01:19 AM Thread Starter
PSD
CNDiesel's Avatar
What benifits are there when you put a 4r100 in place of the e4od?
CNDiesel is offline
post #5 of 10 (permalink) Old 06-14-2009, 03:14 AM
Smarty Power!
More aftermarket options, more sensors to watch, providing you're willing to spend the money...
I'm sure there are more, but it's been a long day and I can't remember them.
Jarrett Matthew
post #6 of 10 (permalink) Old 06-14-2009, 04:08 AM
PSN nerd
the 4r100 has the better hard parts inside it also. the steel tail housing, steel planetary....... over the e40d aluminum parts
and like said above more sensors and other odds and ends. im gonna wait till i can get the 4r100 not gonna waste the money on the e40d. i may just wait till i have the money to get a full built one instead of getting a used 4r100 and putting a good tc, vb and pump mods and run it till it breaks then going through it all the way. if i had the money i would just get a full built one for it.
JAKE is offline
post #7 of 10 (permalink) Old 06-15-2009, 07:16 AM Thread Starter
PSD
CNDiesel's Avatar
How much power can a stock 4r100 with a good TC handle safely?
Would i have to get a built on for 425+hp??
CNDiesel is offline
post #8 of 10 (permalink) Old 06-15-2009, 12:12 PM
Don't EFN worry about it
Aljay's Avatar
I am at just under 380 HP I have done a bunch of boosted 4x4 launches and towed with mine it is still going strong. Do the vb,pump and get a good converter it will go along ways as far as helping it live.
Remmember anything can be broken if abused enough .
Its funny how being without something makes you think twice when you do get it fixed an driving again.
Tuned by T Wildman
Aljay is offline
post #9 of 10 (permalink) Old 06-16-2009, 12:18 AM Thread Starter
PSD
CNDiesel's Avatar
This idea is growing on me more and more.
Did the OBS T-case bolt up to the 4r100? Or were the bolt pattern and out put shaft different?
CNDiesel is offline
post #10 of 10 (permalink) Old 06-16-2009, 04:07 AM
Aljay's Avatar
4r is basiclly a e40d with stronger internals and a few sensors. Yes the T case will bolt up .My 4r came with a cast iron adapter .
Tuned by T Wildman
Aljay is offline
