Wont Start When in Park - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 17 (permalink) Old 06-17-2009, 10:55 PM Thread Starter
cchildress's Avatar
Re: Wont Start When in Park
Originally Posted by PSDTECH97 View Post
go to the dealer and get the a new shifter tube, the 3 plastic bushings and possibly a new shifter it self. pull the 2 plastic covers off the colum and drop it down and it is easy from there. very common problem any good dealer should have every thing there for you.
You say 3 bushings?
I have the diagram in front of me from Ford and it only shows 2 bushings.
I bought the 2 bushings and the shifter tube which is very funny looking. It is metal, and looks pretty heavy. I wouldnt think this thing would wear out that much but quess Im wrong lol.
Any tips before I tear into this.
Thanks, Cody
97 F350, lwb, cc, 4x4
Mods-lots!! To many to list and more to come!!!
Deathrow Inmate #26
cchildress is offline
post #12 of 17 (permalink) Old 06-18-2009, 12:08 AM
ARMY bound
Just remember how you took it apart. It's not too bad to do.
bbbxcursion is offline
post #13 of 17 (permalink) Old 06-18-2009, 12:37 AM
FordCowboy's Avatar
Originally Posted by Jeep1947 View Post
Look under the dash where shift tube comes down there are (2) Torx head screws that tend to back out tighten them up and see it that takes care of your shift problem. Good Luck
Just did this to mine because of the same thing. This was a new shifter tube also, so check those torx bolts, it may be as easy as that. My old one was snapped though which is why I needed a new one so look for cracks in the tube where it mounts at those torx bolts.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #14 of 17 (permalink) Old 06-18-2009, 01:07 AM Thread Starter
cchildress's Avatar
How do you pop the key switch out so I can get the top side of the column off?
Deathrow Inmate #26
post #15 of 17 (permalink) Old 06-18-2009, 01:33 AM
FordCowboy's Avatar
Put the key in and on the bottom side of the cylinder there is a round pin you push in while turning the key and pulling out.
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
post #16 of 17 (permalink) Old 06-18-2009, 01:48 AM Thread Starter
cchildress's Avatar
Thanks I got it. Ok well the two bolts in the back were very lose and the front bushing wasnt even there. I cant figure out how to get to the back clamp off that holds the other bushing. The bolts are on top and no room???
Deathrow Inmate #26
post #17 of 17 (permalink) Old 06-19-2009, 06:17 PM Thread Starter
cchildress's Avatar
Bump
I cant figure out how to get the back clamp off to get the tube out.
Thanks, Cody
Deathrow Inmate #26
