turbo rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-11-2009, 06:58 AM Thread Starter
Clay
fatboy95's Avatar
turbo rebuild
Hey all,
how hard is it to rebuild a turbo on my 95 alot of oil is coming from the intake side of the turbo runs like crap until it warms up then misses until it reaches around 3000 rpm and lots of white smoke comes with it. By the way 366XXX miles on her she has been a great truck
I am pretty good with a wrench I had my local dealer do a test and found out that #5 and #8 injector is failing as well as my IDM about how hard is it to change injectors or should I leave it to a professional.
Thanks for the input that comes
THE FAT MAN
fatboy95 is offline
post #2 of 3 (permalink) Old 06-13-2009, 03:00 AM
Re: turbo rebuild
the turbo is super easy to rebuild and kinda fun too, if you have a good amount of in and out play then you need a new shaft, if you havejust up and down with minimal in and out them youll be fine with a rebuild, may i suggest ronsturboshop?, idm is easy to replace, and injectors arent to bad just tedious.
rideracelivemx7 is offline
post #3 of 3 (permalink) Old 06-13-2009, 06:58 AM Thread Starter
Clay
fatboy95's Avatar
Re: turbo rebuild
thank you I was hoping you would say that
fatboy95 is offline
