OBS Mileage - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 06-11-2009, 12:54 AM Thread Starter
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
OBS Mileage
What are your clocks reading for miles? Please list your miles and any major problems youve had along with MPG.
SMOK'N BLUE STROKER is offline
post #2 of 21 (permalink) Old 06-11-2009, 12:59 AM
Aint going anywhere fast
blackwaterstroker's Avatar
Re: OBS Mileage
well on my old 95 I had 330k miles
new clutch
alt.
tires
bushings
waterpump
2 injectors
glows
ball joints.
thats it!!! I bought the truck with 280k
my 2003 6.0 170k
ball joints
2 injectors
1 egr valve
thats it. I bought it at 140k miles my dad bought it new
1985 Ford F250 XLT
6.9 IDI
C6
Just bought it!
2003 Harley Davidson EG
True duals, Tuner I love it!!!
2012 Nissan 370Z
___________________________
Past trucks
1995 F250 Powerstroke---sold
2003 F250 6.0-----sold
2008 Chevy LMM Dmax----sold
2007 Ford F-150----Sold
blackwaterstroker is offline
post #3 of 21 (permalink) Old 06-11-2009, 01:30 AM
Russ's Avatar
Re: OBS Mileage
200,000 miles So Far... Injectors,icp,cps,fuel pump, tranns starters, alts,track bar bushings, ft, axle joints,flexplate,glowplugs, glowplug relay, seat frame rewelded, I can pull 17 mpg around town(If I can keep my foot out of it). 10 mpg while towing my 7,500 lb 5er.
Stormtrooper:: 1997 F-350 CC SRW PSD XLT 4X4: Baby Swamps, Wildman, SD Intercooler, CCV Mod, shimmed FPR, BTS, Baldwin air filter,triple pillar pod with Isspro gauges, 4" exh, SD dual tensioner mod, diamond cut headlights, Hadley air horns,
Russ is offline
post #4 of 21 (permalink) Old 06-11-2009, 01:43 AM
bluedge8's Avatar
Re: OBS Mileage
i have gotten 17 mpg with my 97 which has 166k miles on it, my 02 e350 I usually get 17 mpg with it but have gotten 19 mpg with it, it has 216 k on it now. I just got my 97 so no parts yet, the van I bought a 144k and have done frt brks, hpop lines, fuel o-rings on top of motor, starter, cps, and batteries, not bad at all!!!
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #5 of 21 (permalink) Old 06-11-2009, 01:59 AM
hit n miss
Peroni's Avatar
Re: OBS Mileage
76200 on my 97 right now. Ate a PCM around 74K, hp power steering line at 72K. No other real problems. Averaging 17-18mpg hwy @ 65mph.
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, 6.0 fan, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, LASB turbo, Spearco 6.0 cac, live tuned 442hp/860tq.
Peroni is offline
post #6 of 21 (permalink) Old 06-11-2009, 06:24 AM
look what i can do
1badpsd's Avatar
Re: OBS Mileage
bought my cc with 154,000 got around 17-18 on the way home. then it got a stage 1's the day it got home. since then blown stock turbo 3 months after i got it,bent pushrods and lots of broken rockers. and im afraid to check the milage lol. its been a pretty good truck so far though cause all the stuff was my fault cause the stock turbo isnt meant to hold 40psi
1badpsd is offline
post #7 of 21 (permalink) Old 06-11-2009, 06:28 AM Thread Starter
HHAUL'N STROKER
Re: OBS Mileage
Sound like 17 mpg is about normal on these. What speeds are you running?
post #8 of 21 (permalink) Old 06-11-2009, 07:05 AM
Clay
fatboy95's Avatar
Re: OBS Mileage
95 extended cab 366XXX tranny @ 210XXX, glow pugs and harness @ 195XXX, themostat @ 350XXX, and finally needs injectors,turbo rebuild, and IDM milage was around 15-18 depending on how I drove her
THE FAT MAN
fatboy95 is offline
post #9 of 21 (permalink) Old 06-11-2009, 11:01 AM
bluedge8's Avatar
Re: OBS Mileage
I drive mostly hwy with the 97 @75 mph, and mix city hwy with the van @ 78mph on the hwy
bluedge8 is offline
post #10 of 21 (permalink) Old 06-11-2009, 01:37 PM
woodduck97's Avatar
Re: OBS Mileage
I get about 18 if I keep my foot out of it. I had to replace the altenater as soon as I bought the truck I washed the engine and then it started charging 18 volts. Then I put helper springs on the front to level it out and help the tired springs. The ball joints were replaced before i got the truck and trans was replaced with a ford reman witch I had to put a torq converter in cause it was rattling so bad it was about to go along when I had the shaft out for 4 wheel drive the u joints were shot. The horn pad had worped on it when it got real cold one night back in the winter and burnt the horns up. $177 dollars from ford with no horns still. This fall its geting new glow plugs there no good either. I have had the truck for about a year now I love it to death I am just having a hell of a time with maintance that needed to have been done to it and never did and for any advice never buy duranco tires the cords break any time you put weight on them both rear tires have went so yesterday I have bought 4 new tires
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
