broken exhaust manifold bolts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-10-2009, 07:13 AM Thread Starter
On the Darkside!!!
HAAS's Avatar
My 1997 f-350 crew-cab,4x4,auto,4 inch Superlift, 226K, PSD popped the head off the drivers side rear exhaust manifold bolt. ANY advice on getting the remaining bolts out without breaking would be great !!!
1997 F-350 4X4 CREW-CAB LONG BED
4 INCH SUPERLIFT, EAGLE 058'S
315/75/16 DICK CEPEK FCII
1997 P-PUMPED CUMMINS, STUDDED TOP
HX40W
TIMING DONE
CUSTOM FUEL PLATE
KDP FIXED
NV4500 SB CLUTCH
DIVORCED NP 205 T-CASE 1410's In and Out
DANA 80 W/DISC BRAKE CONVERSION
HOME FABBED TRACTION BARS
AUTO METER PYRO,BOOST GUAGES
5" MITERED STACKS
HAAS is offline
post #2 of 7 (permalink) Old 06-10-2009, 07:15 AM
BrownBrothersPullingTeam
farmboy8201's Avatar
Re: broken exhaust manifold bolts
if you can weld a nut onto it and then continue out with it, or maybe put a pipe wrench on it and see if you can turn it out that way...the ones that ive broke off i had to re-drill and tap, but i would definately try welding a nut on it if you can get to it...
1999 F350 Lariat extended cab long bed dually, PSD,ported heads, studs, gen 3, 38r/1.15a/r, 300/100, and more Tuned by Matt owner of Gearhead Auto. Perf, John Woods Trans.
2006 F250 XLT 6.0
dual exhaust, egr delete, arp studs, regulated return kit, Modified Direct Clutch Solenoid, SCT Flash custom tuned by Matt, 58 volt FICM w/PHP Flash
farmboy8201 is offline
post #3 of 7 (permalink) Old 06-10-2009, 07:21 AM Thread Starter
On the Darkside!!!
HAAS's Avatar
no can do. its the rear most bolt behind the up pipe. i need to get the manifold off to get to it but i'm worried i'll have more broken bolts. thought about getting some of loc-tites new freeze & release spray and trying it to see if it works.
HX40W
TIMING DONE
CUSTOM FUEL PLATE
KDP FIXED
NV4500 SB CLUTCH
5" MITERED STACKS
HAAS is offline
post #4 of 7 (permalink) Old 06-10-2009, 07:30 AM
not sure on that, ill have to think on that one
2006 F250 XLT 6.0
post #5 of 7 (permalink) Old 06-11-2009, 01:55 AM
<---mud
Dieseltron's Avatar
I had one broke off on mine on the drivers side to. It was rusted in solid into the manifold I had to saw it off as close to the manifold as possible with a dremel . the remaining part still in the head spun right out with a vice grips. the part in the manifold took a big ass hammer and a punch.
good luck
97 F250 4x4 RC Lifted 4 inches. rollin on 35's STT
4" exhaust, Cobalt gauges, HPX, 17* hpop, idm mod, DIY intake,
Intercooled by me
(6700 lbs)
Dieseltron is offline
post #6 of 7 (permalink) Old 06-11-2009, 02:02 AM
moore20017.3's Avatar
I got the same bolt out, but on a SD, probably more room to work with. The bolt was broken off flush with head.
I used a trusty left handed bit, as soon as they bite the bolt comes right out. I had to use a 90* drill however and this was with manifold ON.
After getting a new one in the manifold was warped enough it had to come off anyway DONT tighten the other bolt on that port to try and stop a leak, it WILL warp the chit out of the manifold. I tried.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #7 of 7 (permalink) Old 06-11-2009, 04:33 AM
What else?
smokyred's Avatar
PB Blaster the crap outta the bolts everyday, for 2 weeks, that's what I did. I swore none of the bolts would come out, but 13 did.
The rest of them I torched the heads off and then yanked the manifolds off. After that I just welded nuts onto them and removed with a socket and ratchet.
Dave
smokyred is offline
