No WTS light? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 06-09-2009, 08:47 PM Thread Starter
Harl
Harl's Avatar
Send a message via AIM to Harl
No WTS light?
My dads truck has been acting up on us. The other day the WTS light never came on but the truck started. So I moved it and tried again and the light came on. The trucks been setting for 3days and we went to move it and the WTS light was on but the truck never started. There was no white smoke eaither.. So i new we wasnt getting fuel.. I no there are glowplugs out but i dont no how many. We also put a new relay on it also. So I figured the HPOP res bleed off. So we went to town and got a few thing and came home and I tried to take the resivor plug out and it was on the erge of striping.. So i said forget it and sprayed eaither in and it fired up but the WTS light wasnt on...
So could this be a ECM goin bad or what?
Sorry for the long story. Just trying to figure this thing out.. Thanks
-Cody
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #2 of 2 (permalink) Old 06-09-2009, 10:51 PM
Patrick Feeley's Avatar
Re: No WTS light?
Check underhood fuse #22 (30A Maxi). If it is blown your fuel heater has probably shorted. If this is the case, unplug the spade connector on the driver's side of the fuel filter bowl about halfway down, replace the fuse and try again. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
