Truck seems to have a slight miss - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-08-2009, 11:17 PM Thread Starter
GilroyRacing's Avatar
The truck seems to have a slight miss. It is very noticable at idle, not so bad when cruising, but very noticible under load ( like when going up hill or while towing).
I have been running 2 stroke oil in the fuel, and use power service every other fill up or so.
The air filter is pretty clean, and it has a new fuel filter on it.
Has a lil smoke when its first started in the morning, and smokes black underload.
Any ideas?
96FordF3507.3PSDCC, (Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Cooper Discoverer ATP , 260,000 miles, 3-4" down pipe, 4" exhaust w/5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #2 of 3 (permalink) Old 06-09-2009, 02:56 AM
blageurt's Avatar
Re: Truck seems to have a slight miss
You should try to do an Injector contribiution Test. That way you know which injector is weak. It might be a bad connector on that injector or it could be worn a little compared to the others. I have a couple that run like crap when cold . I will be inserting Stage 1's very soon . . .
blageurt is offline
post #3 of 3 (permalink) Old 06-09-2009, 10:55 PM
Patrick Feeley's Avatar
If you can't get the contribution test done, listen for a loud clicking on one side of the motor. You could always remove the valvecover on that side and check the injector oil spouts for pretty much each injector discharging the same amount of oil. If one isn't discharging much, it could have a loose poppet screw under the solenoid (i've had the happen multiple times), or even a bad solenoid. Cheers!
Patrick Feeley is offline
