help please....light problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-08-2009, 02:38 AM Thread Starter
Black Beauty 7.3's Avatar
im having a problem, when i turn on my lights the brake light above the rear window goes on and the rear brake lights get bright as if the brake lights are on. nad when i step on the pedal they just stay the same. also both blinkers work the lights off but when i turn them on only my rigt blinker works also only one of my blinkers works. Someone told me there is a flasher relay or something that i can access by removing my radio? is this true? thank you.
1996 Ford f-350 7.3l psd Tony Wildman 6 pos chip, 6637 intake, Autometer gauges, 6" silverline aussie stacks
1995 F-Super Duty 5 speed 6637 intake, straight piped
Black Beauty 7.3 is offline
post #2 of 7 (permalink) Old 06-08-2009, 03:23 AM Thread Starter
Re: help please....light problems
im stumped
post #3 of 7 (permalink) Old 06-08-2009, 03:29 AM
Don't EFN worry about it
Aljay's Avatar
Might be a bad turn sig. switch(ford calls it a multi-function switch) they run alot of stuff thru that thing.
Tuned by T Wildman
Aljay is offline
post #4 of 7 (permalink) Old 06-08-2009, 02:50 PM Thread Starter
where is the turn signal switch located?
post #5 of 7 (permalink) Old 06-08-2009, 04:55 PM
oilfield trucker
zpilgeram's Avatar
Under the steering wheel. The turn signal lever is attached to the switch
zpilgeram is offline
post #6 of 7 (permalink) Old 06-08-2009, 08:02 PM
I dunno if this helps but, this happened on my bike one time and the problem was that my wires were connected backwards. I reversed them and the problem went away.
djfootball is offline
post #7 of 7 (permalink) Old 06-08-2009, 08:07 PM
Aljay's Avatar
Tuned by T Wildman
Aljay is offline
