crazy LEAKS!? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 06-07-2009, 12:08 AM Thread Starter
C&C Customs
Cory_S's Avatar
Angry crazy LEAKS!?
ok so i have some crazy leaks going on on my truck! in about 30 min i leaves an oil spot about 6 inches in diameter right off the back of the motor and the whole oil pan is soaked with oil ok well the whole underside of my motor is cover in oil and my tranny is covered in oil and its running down my frame! any ideas is there any oil lines i should check before assuming i need to replace front and rear main seal and oil pan gasket?
stage 11 tranny by Doug @GoGo
And a lot of other goods
_____CORY
Cory_S is offline
post #2 of 11 (permalink) Old 06-07-2009, 01:39 AM
Just another OBS addict
rancherstroker6's Avatar
Re: crazy LEAKS!?
Valve cover gaskets
1995 F250 SCLB 4X4 Auto - '97 D60/10.5" rear, 4.5" PMF RSK/V's, PMF Trac Bars, Sway Bars, MBRP Exhaust, DP F5, Efuel, RRD Diff Cover, Tymar Intake, Isspro Performaxs/Quad Pod, Recon Cab Lights, 05 Lariat SD Steering Wheel
FF250/2's, ARP Studs, Comp Beehives, Smith Bros Pushrods, 1.15 38r, RRD Boost Fooler, 99.5+ Intake, SD 7.3 IC
rancherstroker6 is offline
post #3 of 11 (permalink) Old 06-07-2009, 01:41 AM
Super Hauler!
Super_Hauler's Avatar
Re: crazy LEAKS!?
or dip stick plug on the passenger side of plug.
Super_Hauler is offline
post #4 of 11 (permalink) Old 06-07-2009, 01:57 AM
bluedge8's Avatar
Re: crazy LEAKS!?
also the valley of the motor drains into the flywheel area and will come out of the weep hole in the inspection cover- if your hp oil lines are starting to leak you can have quite a puddle of oil- when i changed my hp oil lines I quit leaking oil all together!
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #5 of 11 (permalink) Old 06-07-2009, 02:01 AM
Super Hauler!
Re: crazy LEAKS!?
Ya check the o rings or just replace them!
post #6 of 11 (permalink) Old 06-07-2009, 02:18 AM
Strokin!
Send a message via Yahoo to 97ps5spd
Re: crazy LEAKS!?
mine did the exact same thing and i ended up replacing the HPOP. It was in the valley of the motor.
2005 F350: Leveling Kit w/35's, S&B, SCT X3 with erics tunes, 4" turbo back straight pipe.
97ps5spd is offline
post #7 of 11 (permalink) Old 06-07-2009, 02:30 AM
97 OBS PSD
Aaron Ford's Avatar
Re: crazy LEAKS!?
Mine did the same thing and it was the EBPV. It sprayed oil out and ran down the back of the block. I was losing 1 quart every 20 miles when I found it. The EBPV stayed clean due to the heat, but directly out from it was covered in oil...
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #8 of 11 (permalink) Old 06-07-2009, 04:20 PM
OEM Moderator
Tom S's Avatar
Re: crazy LEAKS!?
The only way you are gonna get this figured out it to get the old stuff cleaned up and then take a look. I would take a look right before you do that as well though as once in a while you can spot where the leak area is wet but cleaner as it keeps washing away the grime.
Tom S is offline
post #9 of 11 (permalink) Old 06-07-2009, 04:31 PM
PSDfan99's Avatar
Re: crazy LEAKS!?
Some places to check are the HPOP lines, turbo pedestal orings (4 in total), oil galley plugs on the heads (4 in total), oil pan.
I have had all of these spots leak on my truck.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #10 of 11 (permalink) Old 06-08-2009, 03:28 AM
Yoslick's Avatar
Re: crazy LEAKS!?
could be fuel, clean er up real good and get a good light and a mirror and start looking!
DCC(SW/MTS) USN-Ret. 75-95
96 F-250 DIY Intake (NAPA 6637)
3" DP
Gutless Kitty
14.6k Mod
Yoslick is offline
