Truck Wont Start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 06-04-2009, 01:22 PM Thread Starter
BlueTerror's Avatar
Truck Wont Start
Alright i came out in the morning and started my truck up fine with no problems, after that i drove to friends and shut it off for about maybe ten mintues or less. When i went to start it, it wouldnt start untill about the tenth try. It runs perfect once it gets started, it just now when i shut it off it doesnt start at all unless i pull the air filter off and spray a puff of ether into it and crank it, after that it runs with no problems.
Any one have any ideas?
Thanks for the help in advance.
BlueTerror is offline
post #2 of 11 (permalink) Old 06-04-2009, 01:25 PM
Aint going anywhere fast
blackwaterstroker's Avatar
Re: Truck Wont Start
my old 7.3 did that...I put new batteries in and solved that problem
1985 Ford F250 XLT
6.9 IDI
C6
Just bought it!
2003 Harley Davidson EG
True duals, Tuner I love it!!!
2012 Nissan 370Z
___________________________
Past trucks
1995 F250 Powerstroke---sold
2003 F250 6.0-----sold
2008 Chevy LMM Dmax----sold
2007 Ford F-150----Sold
blackwaterstroker is offline
post #3 of 11 (permalink) Old 06-04-2009, 02:32 PM Thread Starter
BlueTerror's Avatar
Ill check and clean the terminals and everything when i get home the batteries are only about six months old
post #4 of 11 (permalink) Old 06-04-2009, 04:31 PM
well you will need glow plugs if you keep spraying either into it. so you shut your truck off and ten mins later it wouldnt start? i think someone had said that would be something with the ipr? something about when the oil gets hot it thins out.
02 f250
countryboyrob is offline
post #5 of 11 (permalink) Old 06-04-2009, 05:36 PM Thread Starter
BlueTerror's Avatar
Ill make sure to check or replace that while im at it, its sitting at home so im not going to be spraying anymore either in it, and ill see if it starts when its cold when i get home.
post #6 of 11 (permalink) Old 06-04-2009, 07:48 PM Thread Starter
BlueTerror's Avatar
Well it wont start when its cold either, so it probably not the ipr if thats from the oil getting hot and thinning out
post #7 of 11 (permalink) Old 06-05-2009, 05:33 AM
my guess is prolly glowplugs then? how warm is it in your area?
02 f250
post #8 of 11 (permalink) Old 06-05-2009, 05:52 AM
BIG RED
BADASSPOWERSTROKE's Avatar
Maybe glow plugs or Gpr mine did the same things before.
99 F250 4X4 7.3 powerstroke, Hybrid injectors By UNLIMITED, 6 position chip with Matts Tunes, K&N INTAKE, 9 INCH SUPER LIFT, 38 inch Nitto Mud Grapplers wrapped around 18 inch Karat rims, 5 INCH straight pipe,gauges, 07 Harley lites, Warn Hubs. H2e on the way 240,000 miles running strong..WV BEAST!!
BADASSPOWERSTROKE is offline
post #9 of 11 (permalink) Old 06-07-2009, 02:02 AM Thread Starter
BlueTerror's Avatar
Alright i changed the relay and the fuel filter, but now i think i ran into another problem, the fuel bowl where the fuel filter goes keeps draining empty and there is no leak any where, because there would be diesel all over my garage fuel.
This looks like it turning into a real headache too.
post #10 of 11 (permalink) Old 06-07-2009, 08:55 PM Thread Starter
BlueTerror's Avatar
I finally got the truck running by just sitting the cranking it for like 30 seconds.
I was wondering tho, if these trucks need back pressure? I dont have an exhaust on at the moment, but it has the stock pancake downpipe on.
95 F-350 Dually XLT
6673 Intake
Custom Speakers
Downpipe Only
Baby Swamps
Electric Fuel
ICP Mod
