OBS powerstroke Front End!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-04-2009, 05:46 AM Thread Starter
ok i have a 1994.5 obs powerstroke regular cab long bed F-250 4x4......when i reverse the front wheels seem to tilt or or kinda camber back almost like a road grater...lol....and lately if i hit a large bump at high speeds the wheel begins to violently shake until i slow down almost to a stop??? any thoughts....
and one more thing...i have a 1996 F-450(superduty) service truck that has the tranny out of it....can i put the large leaf springs off the front of it under my F-250...and possiblely the straight axle with steering stablizer shock on it....any info will help??????
carter09b is offline
post #2 of 9 (permalink) Old 06-04-2009, 05:59 AM
OBS junkie
Cat_Rebel's Avatar
Re: OBS powerstroke Front End!!!
The "camber" issue you describe is normal with all OBS 4x4s. Mine did it & I've seen some really bad ones, esp when you lift them. Sound like the death wobble might be a blown ball joint or even worst your ball joint came loose & rubbed the hole inside & ovaled it out. Happened on the 00, drove perfect except on turn or bumps heard a clunk. Ended up having to buy a new I beam for the drivers side. Not saying that's the issue but something to look at, also double check the tie rods & also check the bushings where the I beam bolts up by the crossmember. Those are known for going bad. When I would back up & hit the brakes I would hear a CLUNK everytime. Swapped in my Dana 60 & no more noise.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 9 (permalink) Old 06-04-2009, 06:02 AM Thread Starter
alrite thanks man.....ill take a look at it....sorry im not real good with suspension "terms"....im just a college student driving an old farm truck and those "death wobbles" sure wake u up going down the highway to class!
post #4 of 9 (permalink) Old 06-04-2009, 06:03 AM Thread Starter
and by the way...my truck is 100% stock ride height
post #5 of 9 (permalink) Old 06-04-2009, 12:05 PM
Just another OBS addict
rancherstroker6's Avatar
Sounds like you need to set up ur sig (signature, appears at the bottom of your posts). I was gonna say ball joints too, they need a little rebuilding . And I would think you could do the front end swap, someone will come along that will know for sure. Get some pics posted...post 'em in this thread:
https://powerstrokenation.com/forums/...ad.php?t=19949
and tell us what all you got on it, if anything. Or maybe some future plans for it
1995 F250 SCLB 4X4 Auto - '97 D60/10.5" rear, 4.5" PMF RSK/V's, PMF Trac Bars, Sway Bars, MBRP Exhaust, DP F5, Efuel, RRD Diff Cover, Tymar Intake, Isspro Performaxs/Quad Pod, Recon Cab Lights, 05 Lariat SD Steering Wheel
FF250/2's, ARP Studs, Comp Beehives, Smith Bros Pushrods, 1.15 38r, RRD Boost Fooler, 99.5+ Intake, SD 7.3 IC
rancherstroker6 is offline
post #6 of 9 (permalink) Old 06-04-2009, 12:08 PM
all ur OBS r belong to me
OldschoolPSD's Avatar
Send a message via MSN to OldschoolPSD
The wobble could also be axle pivot bushings.
Ford stopped building trucks in 1997
OldschoolPSD is offline
post #7 of 9 (permalink) Old 06-04-2009, 05:33 PM Thread Starter
well i replaced the ball joints and we are gonna see how it works for now....im still thinkin on switching the front ends....anyone ever done this? F-450 to F-250 swap??
thanks guys
post #8 of 9 (permalink) Old 06-04-2009, 07:37 PM
Strokin!
Send a message via Yahoo to 97ps5spd
i ended up doing tie rods and tie rod ends and all new ball joints on mine
97ps5spd is offline
post #9 of 9 (permalink) Old 06-05-2009, 12:13 AM
OBS junkie
Cat_Rebel's Avatar
thanks guys
If your F250 is 4x4 you would loose your 4 wheel drive. It's a 10 lug setup so you would have to run diffrent wheels on the front then the back. Also mesure your spring perches on both they might not be the same but I want to say they should be.
RIP Will Iott
