Gauge install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-03-2009, 07:11 PM Thread Starter
bluedge8's Avatar
Gauge install
I just got my Isspro gauges in the mail, I have a few basic questions on install- where do you put the boost sensor in?, where have guys tied in to the dash lights, do you use a specific circuit to power the gauges themselves, can a guy "quickly" install trans temp sensor without complete drain and fill? I assume people are just finding room under the drivers side of the dash for the gauge electronics. thanks in advance
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #2 of 9 (permalink) Old 06-03-2009, 08:51 PM
Re: Gauge install
Read this links
http://www.egauges.com/ISS_Inst.asp#R4000
http://www.dieselmanor.com/installsheets.asp
http://www.thedieselstop.com/faq/949...ks/gauges.php3
Gauge Install
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #3 of 9 (permalink) Old 06-04-2009, 03:54 AM Thread Starter
bluedge8's Avatar
Re: Gauge install
thanks for the links, I did a quick search and didn't find anything.
bluedge8 is offline
post #4 of 9 (permalink) Old 06-04-2009, 03:49 PM
Wink Re: Gauge install
You are welcome, any time. Dont hesitate to make any question do you have.
post #5 of 9 (permalink) Old 06-04-2009, 10:04 PM
97 OBS PSD
Aaron Ford's Avatar
Re: Gauge install
I tied in to the radio power wire and the illumination wire for the lights. The tranny senson is very easy to install and I lost little to no fluid. I didn't take all day doing it, though. If your sensor is a multiple wire unit, use teflon on the threads. If one wire, install dry. The boost sensor comes off the map hose.
HTH
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #6 of 9 (permalink) Old 06-04-2009, 10:07 PM Thread Starter
bluedge8's Avatar
Re: Gauge install
it helps, I was thinking map sens hose when I was looking at it, and I do want the gauge lights dimmed with dash lights so that sounds like a good place to power up the gauge lights. one of the above links has a picture of the egt probe location on the manifold and that really helps, thanks.
bluedge8 is offline
post #7 of 9 (permalink) Old 06-04-2009, 11:17 PM
Re: Gauge install
When I did mine iI ran the pyro wires and the trans temp wires down the gromet that the shift cable goes through, very close to both locations.
Red97 is offline
post #8 of 9 (permalink) Old 06-05-2009, 12:51 AM
97 OBS PSD
Aaron Ford's Avatar
Re: Gauge install
You will find the manifold very easy to drill. The gauges took an hour or so to put in, but only 15 minutes to hook up.
Aaron
post #9 of 9 (permalink) Old 06-05-2009, 01:25 AM
cntryboy17's Avatar
Re: Gauge install
when i did mine they were easier to install then i thaught
E99 F-350 CCSB 4x4
1990 F250 7.3idi 4x4 5 speed- SOLD!
cntryboy17 is offline
