Starting issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-02-2009, 07:54 PM Thread Starter
Got Whistle?
crack_7.3's Avatar
Starting issue
my ol mans friends Dad has an OBS and hes having issues starting, even when its warm out...says if he cycles the GPs one it will crank and crank but wont fire...but if he cycles them 2 or 3 times it will turn over and fire, and blow white smoke...other than that it runs well.. he said the glow plugs and GPR was replaced not long ago....could it just be a bad batch of GPs? thanks in advanced guys
08 F350 Lariat
Blacked
IDP tuned SCT
crack_7.3 is offline
post #2 of 6 (permalink) Old 06-02-2009, 09:23 PM Thread Starter
Got Whistle?
crack_7.3's Avatar
Re: Starting issue
oh and if he plugs it in it starts...but who wants to plug in at +20* C
08 F350 Lariat
Blacked
IDP tuned SCT
post #3 of 6 (permalink) Old 06-03-2009, 02:50 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: Starting issue
probably has a bad glow plug, but check the connectors on the valve cover gaskets first
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #4 of 6 (permalink) Old 06-15-2009, 07:07 PM
Re: Starting issue
I also have this same problem. She runs fine once the engine warms up and all but on starting after sitting for a night or days it has to be cycled.
GPs are not fun from what I hear. Any other ideas as to what it could be.
Someone I know said maybe the fuel heating element? Maybe something else?
1995 F-350 CC - Dually Longbed Under work...
S+B Intake. MBRP 3"DP-4"Exhaust. TS Performance 6 Bank.
Stroke It Again is offline
post #5 of 6 (permalink) Old 06-15-2009, 07:14 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Re: Starting issue
Gary I feel is correct. I had the exact same problem. Turned out to be Bad UVC wiring. GP were fine, but changed anyway. Relay was fine too. Starts much better after the UVC harness/ VC gasket changeout/.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #6 of 6 (permalink) Old 06-15-2009, 08:09 PM Thread Starter
Got Whistle?
crack_7.3's Avatar
Re: Starting issue
UVC eh...perhaps I'll have to check that..
08 F350 Lariat
Blacked
IDP tuned SCT
