No instrument lights - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 06-02-2009, 07:56 AM Thread Starter
Ears93's Avatar
The illunination lights do not work on my instrument cluster and the high beam indicator is on when the high beams are off and it goes off when I turn the high beams on.
The gauges will quit working at times but that is due to the printed circuit on the cluster being warped and I have to take it out and move it around.
Just want to make sure there isn't anything else to cause my lights to do this or is it more than likely my printed circuit?
The next cluster I get I plan on putting one from a 99 F350 so I can have a factory type tach and I don't want to chase all the same problems after I have moved all the pins around in the connectors.
Thanks in advance!
Nick
97 E350
Muffler+Cat Delete with a 6inch MBRP Tip
Rebuilt E4OD with updated steel drums, updated planetary set, additional clutches, heavy duty torque convertor, shift kit, an additional cooler, and a few other updates.
More to come but I won't bore you with that till it's done.
Ears93 is offline
