PSD stalling when warm - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-01-2009, 08:16 PM Thread Starter
Hey I have a 97 Ford f350, 7.3l,a/t, and 221k on the truck. The truck takes a bit to get started then will die when the motor warms up. and will not refire till motor cools down. The truck will also die on decceleration when the motor gets warm. I have searched and have done the following
* Swaped IDM
* Replaced CPS
* Replaced injector o-rings
* Replaced IPR o-rings
* New Glow plugs
* One of the glow plug harness' had a bad wire so i swaped that too
* Oil/Filter
* fuel filter
Where should I go from here?
Grama is offline
post #2 of 7 (permalink) Old 06-02-2009, 01:56 AM
pjwoolw's Avatar
Re: PSD stalling when warm
Welcome to PSN. I would check fuel pressure first. Have you cleaned the FPR screen in the fuel filter / water separator?
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
pjwoolw is offline
post #3 of 7 (permalink) Old 06-02-2009, 05:29 AM Thread Starter
Thanks Pjwoolw!
I clean the screen but havnt drained the water separator. Where is the water separator located?
Grama is offline
post #4 of 7 (permalink) Old 06-02-2009, 11:06 PM
ADubDiesel's Avatar
It's a little lever on the back of the fuel filter housing. IIRC it's yellow in color.
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #5 of 7 (permalink) Old 06-03-2009, 04:31 AM
OEM Moderator
Tom S's Avatar
It sounds to me like you do not have enough HP oil when the oil is thin and warm. I would be monitoring that for some diagnosis.
Tom
Tom S is offline
post #6 of 7 (permalink) Old 06-03-2009, 11:45 PM Thread Starter
where can a monitor the hp oil at?
Grama is offline
post #7 of 7 (permalink) Old 06-04-2009, 12:03 AM
Starting Over
kainers's Avatar
Did you rebuild the IPR or just replace the orings?
Not that he doesn't have enough to do but CSIPSD lives in bend Pm him he has AE and can do a scan on your truck monitor you HPO psi.
kainers is offline
