brake help? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-01-2009, 03:29 AM Thread Starter
97psd4x4's Avatar
Angry brake help?
ive got a 250 4x4. went today to change my brakes got everything of pads,caliper and such. tried to get the caliper mount of to pull the rotor off first i tried an impact...no go second got a ratchet broke to of them finally grabbrd a breaker bar and a socket nothing.used a whole can of penetrant too. ive never had this much trouble with rotors. if anybodycould help it would be great.
1997 F250 xlt 4x4 lwb
tymar intake tw tunes
5" exhaust w/ 7" Mitres
3 pillar autometer gauge pod
20" rims 37" SS M16
4" lift Road Armor 10,000 warn
built tranny fpr shim '01 IDM
97psd4x4 is offline
post #2 of 6 (permalink) Old 06-01-2009, 07:19 AM
Terminator Nation
Re: brake help?
Spray it down with Kroil or PB Blaster and let it soak for awhile. The bolts are torqued to a fairly high number.
old man dave is offline
post #3 of 6 (permalink) Old 06-01-2009, 08:20 AM
GoNavy!
DcMoore999's Avatar
Re: brake help?
Danny (Imelmo) recently posted a thread on a mix for rusted bolts...Mix 50-50 ATF and acetone, try that and if it doesn't work put some heat on it.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #4 of 6 (permalink) Old 06-02-2009, 01:51 AM Thread Starter
97psd4x4's Avatar
Re: brake help?
finally got it off today with a breaker bar and cheater pipe from work. gonna finish up tom with all new bearings and seals. by the way does anybody know if the older 250' bearings are pressed in or what. thanks
20" rims 37" SS M16
97psd4x4 is offline
post #5 of 6 (permalink) Old 06-03-2009, 01:51 AM
Terminator Nation
Re: brake help?
The spindle/rotor bearings are not pressed in. The bearings supporting the axle may be.
post #6 of 6 (permalink) Old 06-03-2009, 02:45 AM
Fixing Broken Stuff
toolmangary's Avatar
Re: brake help?
Some of these bolts may have lock tight on them, you may have to heat the spindal, then use your impact
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
