Codes from my truck - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-17-2007, 02:51 AM Thread Starter
Question Codes from my truck
Howdy all,
last couple of weeks I have been having problems with my truck. 1st multiple fuel leaks, got those fixed and now what appears to be transmission problems. Truck shifts hard into 1st and 2nd and then is fine. Here are the codes it is throwing:
P1280 ICP CKT Out of range low
P0113 IAT CKT High input
P1284 ICP Fault
P1718 Transmission control switch out of range
P0476 Exhaust pressure control valve
Thanks,
Craig
HappeetxnR.N. is offline
post #2 of 4 (permalink) Old 11-17-2007, 06:26 PM
OEM Moderator
Tom S's Avatar
Re: Codes from my truck
I think your transmission problem might be a bad range selector switch. One of the smart tranny guys would know for sure. A couple of the others are common on a modded truck. The P0113 IAT CKT High input makes me wonder if you have the intake air sensor plugged in.
Tom
Tom S is offline
post #3 of 4 (permalink) Old 11-17-2007, 06:45 PM
Do you have the diagnostic info to trouble shoot the codes? They should be checked in the right order. Either fuel, oil, or tranny related codes are to be fixed first. Then codes cleared and retested. Some codes are caused by the malfunction itself and are false--"ghost" codes.
The pcm is really just dumb, or it would be capable of isolating the exact failure. It needs a human to figure out the real problem. As Tom said, make sure that sensor is plugged in.
Racer X is offline
post #4 of 4 (permalink) Old 11-17-2007, 07:39 PM Thread Starter
Here is what I have found.......a bad ICP. While fixing a fuel leak I unknowingly broke the connector on top of the ICP. Got a new one today and most of my issues have resolved.
I have a modified air intake and exhaust so that might be why those codes are showing.
I appreciate the input fellas.
Craig
