Anyone have an online ECU pinout - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 11-14-2007, 04:48 AM Thread Starter
Turbo Junkie
Trying to trace signal wires from the ECU. TDE1 program - I know that doesn't change the pin out. Just looking for info on line if anyone has it or knows where to find it. I can find tons of the 87-93 Mustang ECU, the written code and everything, but haven't been very lucky with the truck.
1997 F250 HD 4x4 Auto, Original owner
Mick is offline
post #2 of 13 (permalink) Old 11-14-2007, 01:28 PM
<-Friends bike
Re: Anyone have an online ECU pinout
I have one I can E-mail to ya ....
PM your address....
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
ActionRick is offline
post #3 of 13 (permalink) Old 11-14-2007, 05:36 PM
Bigfoot is an OBS
cowboy_dan's Avatar
In sig.
Go ARMY!
cowboy_dan is offline
post #4 of 13 (permalink) Old 11-17-2007, 12:59 AM Thread Starter
Turbo Junkie
Thanks guys, both helped. Now I need to get off ofo the computer and spend some time with the VOM ringing out the harness. Very much appreciated.
Mick is offline
post #5 of 13 (permalink) Old 11-17-2007, 01:33 AM
OEM Moderator
Tom S's Avatar
Mick what are you working on?
Tom
Tom S is offline
post #6 of 13 (permalink) Old 11-17-2007, 04:34 AM Thread Starter
Turbo Junkie
Transmission OD off isn't working after rebuild. No flashing light, just won't keep Torque Converter from locking.
Mick is offline
post #7 of 13 (permalink) Old 11-17-2007, 01:26 PM
Madvan's Avatar
Did the lamp work before?
Also the cancel switch is for OD not the TC.
Bill
97 Quigley 4X4 PSD
Madvan is offline
post #8 of 13 (permalink) Old 11-17-2007, 04:40 PM
X Racer
Racer X's Avatar
Tom
Tom,
He wants to continuity test his harness from the PCM connector. Banks, has him calling it the ECU because of their instructions for trans com and they don't know FORD.
Mick, is it the converter your trying to use OD cancel to lock and unlock? Please read Madvan's post. If so, you don't have a problem. That would explain why no codes are set.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #9 of 13 (permalink) Old 11-17-2007, 06:52 PM Thread Starter
Turbo Junkie
Poor wording on my part.
What is the difference overdrive and locking the torque convertor?
Mick is offline
post #10 of 13 (permalink) Old 11-17-2007, 07:03 PM
X Racer
Racer X's Avatar
Converter lock is to improve the efficiency of engine power. It has nothing to do with the gear ranges of the transmission. Canceling OD only allows gear ranges 1-2 and 3.
Racer X is offline
