oil pressure sender fitting size - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-08-2007, 10:47 PM Thread Starter
PSN nerd
is this boss oring -4????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #2 of 11 (permalink) Old 11-09-2007, 01:25 PM
racehauler's Avatar
Re: oil pressure sender fitting size
I have seen someone post that it is but don't know for sure.
If you have a -4 JIC or AN fitting laying around try screwing it into the threads. If it is the same then it is -4 ORB
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 11 (permalink) Old 11-10-2007, 03:23 AM Thread Starter
PSN nerd
i cant seem to find my box of hydraulic fittings, oh well i got some 1/8" npt bungs so im gonna burn one in for a sender for a REAL oil pressure gauge
JAKE is offline
post #4 of 11 (permalink) Old 11-10-2007, 09:25 PM
Yes, it is.
TerminatorEngineering is offline
post #5 of 11 (permalink) Old 11-11-2007, 12:48 AM Thread Starter
PSN nerd
too bad i cant find anybody that makes a -4 oring boss to 1/8npt female, im just gonna drill it out and put a 1/8" npt weld in bung for the pressure gauge. ive had it in a hole i d&t'ed but since the stupid sender you cant use thread sealant on it seeps since you cant get it tight enough. i wish i could have gotten theese senders in oring boss.
JAKE is offline
post #6 of 11 (permalink) Old 11-11-2007, 01:35 AM
OEM Moderator
Tom S's Avatar
Why no thread sealant? Are the threads the ground for the sender? I would try using just a small amount of pipe dope and then check the resistance with the meter to see.
Tom
Tom S is offline
post #7 of 11 (permalink) Old 11-11-2007, 01:08 PM Thread Starter
PSN nerd
yeah the sender grounds through the threads, thats why i was gonna put that bung in there so i can get it a bit tighter. but the oring boss is so much better for this situation, i was gonna try to run it in till it seats some then use a little grey rtv on the last couple top threads and run it down the rest of the way. atleast the senders are 1/8npt so its a real fine thread i just dont want it to leak at all.
oh yeah one other one does anybody know what thread the coolant temp threads are? i cant remember what it was havent had it out in a long time.
im workin on getting my new oil, and fuel pressure in, coolant temp, and fuel level. for theese im just using the cyberdyne digitals, i like just having the digital with idiot lights. i wanted the spa gauges like my pyro/boost but the cost.
JAKE is offline
post #8 of 11 (permalink) Old 11-12-2007, 04:27 PM
racehauler's Avatar
You might want to call Bill at Dfuser. He has a fitting that is used for installing a fuel pressure gauge that might be -4 ORB.
http://www.dfuser.com/mfg/powerstrok...ther/Other.php
It's at the bottom of that page.
Eric
96 F-350 CC Dually
post #9 of 11 (permalink) Old 11-12-2007, 10:36 PM Thread Starter
PSN nerd
SWEET!! thats the fitting so now i shouldnt have to worry about welding that bung in place and since the adapter is steel i can get the sender goodentight and not worry about overtightning into the aluminum. and $10 aint worth all the prep time to get the tank clean enough to tig it and i dont know if that cast al will weld up worth a turd
JAKE is offline
post #10 of 11 (permalink) Old 11-13-2007, 03:17 PM
racehauler's Avatar
Like I said before you better confirm that the fitting is a -4 ORB before you order.
Eric
96 F-350 CC Dually
