Electrical issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 07-26-2007, 02:26 AM Thread Starter
Hog Whisperer
tater97's Avatar
Electrical issue
I got no speedo,no odometer,no overhead cab light and no "courtesy bell" Whats up? Any ideas/ Tater
1997 Ext. 4x4 5 spd, All green finally!,Beans 1's, Tymar, 3"-4" DP Exhaust, Shimmed FPr 1.0 Turbo,6Pos TONY WILDMAN burn. Okiecooler, ccv mod, SouthBend ConFE,superduty spring packs,17* hpop
Number19
tater97 is offline
post #2 of 11 (permalink) Old 07-26-2007, 03:36 PM
racehauler's Avatar
Re: Electrical issue
Have you checed the fuses yet?
Those all sound like they would be on the same circut.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 11 (permalink) Old 07-26-2007, 04:19 PM
Laces Out
bigrpowr's Avatar
im guessing the fuses. one circuit gone bad.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #4 of 11 (permalink) Old 07-26-2007, 04:32 PM Thread Starter
Hog Whisperer
tater97's Avatar
Yes it keeps popping #8. Which direction should I head? any common pinch point that may be shorting it out?
Number19
tater97 is offline
post #5 of 11 (permalink) Old 07-26-2007, 05:13 PM
Taters #2 Fan
JohnDeere9610's Avatar
Send a message via AIM to JohnDeere9610 Send a message via Yahoo to JohnDeere9610
Tate if its your dash light then its your running lights. I had my licenses plate light wire come lose and grounding out on my hitch. if I hit a bump right it would ground and go dark
RDRCM# Five O
95 F350
Full Force stage 3 Hybrids
H2E
2L Motorsports Gen 3
Beans fuel system
Transmission by Jon Faubion
Tuned by the "WILDMAN"
99.5 Dodge
P-Pump 24v
2.6 puller
"Whitey"
JohnDeere9610 is offline
post #6 of 11 (permalink) Old 07-26-2007, 06:01 PM Thread Starter
Hog Whisperer
tater97's Avatar
no i got dash lites, just no speedo move, no odometer...thanks tate
Number19
tater97 is offline
post #7 of 11 (permalink) Old 07-26-2007, 09:43 PM
Taters #2 Fan
I have no idea man good luck.
RDRCM# Five O
95 F350
H2E
Beans fuel system
99.5 Dodge
P-Pump 24v
2.6 puller
"Whitey"
post #8 of 11 (permalink) Old 10-18-2007, 01:40 AM Thread Starter
Hog Whisperer
tater97's Avatar
Resurrection.... Ok any new guys got some simple schematics or drawings on where wires go from the fuse beyond...please help its throwing off my maintenance and I am sick of it....
Number19
tater97 is offline
post #9 of 11 (permalink) Old 10-18-2007, 03:46 PM
Bill
badford350's Avatar
I know on my obs I had higher wattage head light bulbs that would burn out the switch itself. They were pulling more amps and creating much more heat. the back of the plug was turning to burn brown from grey. As for the Spedo I had the same from the connector on the rear end getting full of mud. took it apart and cleaned it. worked perfect after that.
02 f350 larit, itp rr & pre pump filter, GTP38r, international up pipes, swamps 175/146 single shot's, DP tuner, factory tech valve body & lot of extra lights
badford350 is offline
post #10 of 11 (permalink) Old 10-18-2007, 04:35 PM
I don't see any common pinch points in the circuit. It's a short as it blows the fuse. The circuit is hot all times (ign off). It feeds from the under hood fuse box. Should be 15 amp fuse, 95-96 anyway. Here's whats on the fuse: Courtesy lamps (doors and jab switches) Underhood light, power mirrors, Vanity mirrors(i'm guessing this was an option on the visor mirror--wire from the roof might rub) Speedo memory, warning chime, keyless entry, Dome light (feeds thru head light switch) If the truck is an XLT the rear cargo light on the cab roof is part of the courtesy lamps. I'd look for chafed wires where I could. If none found, I'd disconnect everything on the circuit one by one to find the short. You also could rig a 15 amp circuit breaker and substitue it for the #8 fuse. That will give you more time to run it down as the breaker cycles without damage to the wiring. Hope that helps.
Racer X is offline
