Turbo wheel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-02-2007, 08:53 AM Thread Starter
Turbo wheel
Just wondering what would be a good wheel for my turbo? 97
Jason Reimer is offline
post #2 of 8 (permalink) Old 11-02-2007, 01:30 PM
racehauler's Avatar
Re: Turbo wheel
The one that's in it
If you are needing to replace it due to damage you can get one of the wicked wheels but it is the same exact wheel as the stock one.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 8 (permalink) Old 11-02-2007, 03:10 PM
OBS junkie
Cat_Rebel's Avatar
Re: Turbo wheel
What happened to your wheel Jason?
The 94-early 99 all had the "Wicked Wheel" which is what you have right now. All you need to do is find another Wicked Wheel & you'll be all set. Just about everyone & their brother sells one. But if you get the banks wheel & put the sticker on your truck it will add over 35hp on the new wheel alone. The sticker is worth at least 100hp.
In all truth though get ahold of Garrett Shields www.puredieselpower.com
He can get you one & is a great guy to deal with.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 8 (permalink) Old 11-02-2007, 04:14 PM Thread Starter
Re: Turbo wheel
Nothing happened to it. I was just wondering how to get a little more out of my truck
post #5 of 8 (permalink) Old 11-02-2007, 08:31 PM
OBS junkie
Cat_Rebel's Avatar
Re: Turbo wheel
You probley going to be looking at a bigger turbo & injectors. Did you replace your stock down pipe? That will hold you back alot!
Just get the DP Tuner while your at it!
RIP Will Iott
post #6 of 8 (permalink) Old 11-03-2007, 01:01 AM
Big_Dan97's Avatar
Re: Turbo wheel
A downpipe will getcha a lot.
97 PSD 34
470hp/940tq, FFD, BDP, TW, RockinSPerf, Tymar, Stealth Oil, modded H2E, 230 cc a codes studs&springs, dual 4" exhaust, 7.3 IC, gauges, TC LU,TC/shiftkit, Family rig:02 7.3 Excursion tymar intake, 4"mbrp tb, evo 2
Big_Dan97 is offline
post #7 of 8 (permalink) Old 11-04-2007, 02:00 PM Thread Starter
Re: Turbo wheel
Just ordered a 3" down pipe.So you think that could be it?
post #8 of 8 (permalink) Old 11-04-2007, 05:44 PM
Big_Dan97's Avatar
Re: Turbo wheel
Youll be amazed the difference a downpipe will do, (plus the truck sounds better) that was my first mod. Second was a k/n intake, (do not do k/n do tymar or a diy like a tymar) and the list grew from there! DP isnt to bad, unbolt it cut it where you like, push it up cut it again, push it down cut it again, do that until it falls out. Theres a pinch seam on the firewall you flatten out and the new one slides down. Its not too bad, just take your time and be careful when cutting, i covered the turbo with a rag even though its the outhole I still covered it. If you have problems just post a new thread.
Dan
97 PSD 34
