motor slugish when cold - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 10-31-2007, 01:27 AM Thread Starter
Bigfoot is an OBS
cowboy_dan's Avatar
In the morning when I leave for work, it is slow to rev up until it hits about the 2krpm mark. Then it revs fine. I know it's not my imagination, it's much too noticeable to be that.
It's done this since I've had it.
The motor has to cool off completely.
Overnight temps are around 45-50, about 50 when I leave.
It get worse as the weather gets colder.
Once I can just start to feel heat out of the vents is when it starts to improve. Generally about 3-7 minutes.
By 10 minutes, in all but really cold weather, it is running fine. In really cold weather (0-10 deg f) it takes about 15 min.
It does it in all programs, and it did it before I did anything other than change the oil & air filter.
Is this programmed to happen, or do I have a temp sensor on the way out?
Go ARMY!
cowboy_dan is offline
post #2 of 34 (permalink) Old 10-31-2007, 01:53 AM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Re: motor slugish when cold
I kind of have the same problem. I was thinking it was just because it was cold. I hope thats all it is lol
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #3 of 34 (permalink) Old 10-31-2007, 01:58 AM
Dieselized
bluetech151's Avatar
changing your oil to the 30 sae will help
You call yourself a mechanic, you can't even fix a mechanical pencil.
bluetech151 is offline
post #4 of 34 (permalink) Old 10-31-2007, 03:29 AM
racehauler's Avatar
What you are noticing is the EBPV closing. When it restricts the exhaust to warm the engine up it will rob some power. This is normal operation.
You can disable it if you want but warm up time will be longer.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #5 of 34 (permalink) Old 10-31-2007, 03:41 AM
dinnerbooter treasurer
genuineford's Avatar
^^^ what he said
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #6 of 34 (permalink) Old 10-31-2007, 04:21 AM
Proud PSN Sponsor!
Strictly Diesel's Avatar
There's more to it than that. Programming is adjusted for cold operation, so the engine does run differently. The EBV is also part of it.
Dennis Schroeder - Co-Owner of Strictly Diesel
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
post #7 of 34 (permalink) Old 10-31-2007, 04:35 AM
Do you smell something?
Wackerjr's Avatar
you have to remember as well your injectors are fired by oil.........
cold thick oil is harder to pump than warm thin oil.....hence the better running when heat starts out the vents.
Wackerjr is offline
post #8 of 34 (permalink) Old 10-31-2007, 12:59 PM
so nothing serious.
sweet
post #9 of 34 (permalink) Old 10-31-2007, 01:31 PM
OBS junkie
Cat_Rebel's Avatar
I'd unplug it but if it's still sticking I'd get the delete kit. Sometimes those things get old & will get stuck in the partly closed position. In other words you may as well be driving with an exhaust brake on.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #10 of 34 (permalink) Old 10-31-2007, 02:43 PM Thread Starter
Bigfoot is an OBS
cowboy_dan's Avatar
It's no longer automaticaly actuated. I cut the wire from the PCM and the actuator is on a switch.
Go ARMY!
