emergency info 97 stroker - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-25-2007, 01:58 AM Thread Starter
Question emergency info 97 stroker
i just parked my 97 <95,000 mile > tonight , ran fine all day .now it wont start ! it cranks ,but doesnt fire. no smoke just cranking like an ole chevy without the coil wire hooked up! replaced the CPS with no luck same problem . this is my main tranportation please help with any info .thanx ,
greaseballcreeper is offline
post #2 of 13 (permalink) Old 10-25-2007, 02:03 AM
OEM Moderator
Tom S's Avatar
Re: emergency info 97 stroker
Well for a start do you have a wait to start lite?
Tom
Tom S is offline
post #3 of 13 (permalink) Old 10-25-2007, 02:05 AM Thread Starter
Wink Re: emergency info 97 stroker
yes ,same delay
post #4 of 13 (permalink) Old 10-25-2007, 02:05 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Make sure you have fuel pressure at the shrader valve.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #5 of 13 (permalink) Old 10-25-2007, 02:26 AM
OEM Moderator
Tom S's Avatar
hot or cold motor when it will not restart?
Tom S is offline
post #6 of 13 (permalink) Old 10-25-2007, 02:36 AM
OEM Moderator
Tom S's Avatar
Tom S is offline
post #7 of 13 (permalink) Old 10-25-2007, 02:36 AM
member
Mine did that when injector oring failed and it would not build high pressure oil.
F350cc4x4sb,BTS Trans, H2E Turbo,Tapor core IC,530mm injectors,Head studs,DI regulated return and total fuel system.
Astnpwr is offline
post #8 of 13 (permalink) Old 10-25-2007, 03:39 AM Thread Starter
cold start ????
post #9 of 13 (permalink) Old 10-25-2007, 04:08 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
cold start=sat over night cold start in the A.M. Engine was allowed to cool to ambient temps.
This is the first time you've had this problem?
2005 F-250
post #10 of 13 (permalink) Old 10-25-2007, 06:17 AM
X Racer
Racer X's Avatar
Usually there will be some rough running before it gets to this point. A clue is tiny bits of black rubber like stuff in the fuel filter housing.
Maybe he got it going.
Cold: fuel heater short. Tom, is that what you were isolating with cranking temps?
Some common causes in no particular order:
IPR, IPR coil bad or loose. IPR harness, fuel pump, HPOP reservoir leak down, low oil level, oil additives like engine restore, glow plugs, GP relay, GP harness. CPS should be covered already. No smoke = no Fire.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
