Wheel bearing, brake question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-19-2007, 02:39 PM Thread Starter
charlie99's Avatar
Driving my truck last night and pretty sure my wheel bearing went out on the passenger side, but when this happened I lost my brakes as well, the brakes still work but it just feels like there not power any more. Any ideas guys would really help.
'95 PSD 3" RSK, 3" bodylift, 37x13.50x20 xterrains. Tymar intake,ARP studs, comp 910s, DIY 238 hybrids with 200% nozzles, 6.0 intercooler, 3.5" downpipe to dual 4" stacks, CCV mod, IDM mod, DP tuner mod stock, 40t, 80e, 140r, fass 150/180, ITP regulated return, TE big oil, GTP38r turbo, lookin for 500 ponies
charlie99 is offline
post #2 of 6 (permalink) Old 10-19-2007, 02:52 PM
X Racer
Racer X's Avatar
Re: Wheel bearing, brake question
Not sure on your wheel bearing. Usually they make heat when bad you can feel by touching the hub.
Your hard brake pedal is a sign the vacuum pump on the engine is weak or the lines to booster are leaking. Diesels make little vacuum so the pump is used for power brake assist. It's located by the power steering pump.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #3 of 6 (permalink) Old 10-19-2007, 02:57 PM
OEM Moderator
Tom S's Avatar
If you pump up the pedal after the truck is stopped do they feel normal again? If they do I think that would be related to the wheel bearing issue and fixing that will fix the brakes. If they are still not right then the areas Bill suggested sound right to me.
Tom
Tom S is offline
post #4 of 6 (permalink) Old 10-19-2007, 02:59 PM Thread Starter
charlie99's Avatar
Actually its a very soft pedal, the rim was hot but i couldn't feel the hub because of center cap, it was also pulling towards the passenger side
post #5 of 6 (permalink) Old 10-19-2007, 04:27 PM
OEM Moderator
Tom S's Avatar
And it will not pump up?
Tom
Tom S is offline
post #6 of 6 (permalink) Old 10-19-2007, 05:54 PM
X Racer
Racer X's Avatar
I would try raising the wheel and pumping the pedal. See if the rim/wheel turns after pumping or if the brake is holding it. Look for any sign of fluid leaks.
If you have been off-roading or curb hopping and hit anything on the right side, could be something else causing the heat.
Racer X is offline
