EBP sensor question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-16-2007, 05:12 PM Thread Starter
racehauler's Avatar
EBP sensor question
I am not having any problems with my EBP sensor but am anticipating the day that I do. I know the tube that goes from the manifold to the sensor has a tendancy to clog up and sometimes rust through.
What I am wondering is if you pull the tube off, put a plug in the manifold and leave the sensor wired up and on the engine just reading atmospheric pressure (0 psig) will this pose any problems?
Do you think I will get a code or CEL from it? I wouldn't think so since the wiring is still plugged into the sensor.
Is there anything within programming that uses EBP to adjust pulse width?
I know it would be a bad thing to do if you have a EBPV but mine is gutted.
What are your thoughts?
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #2 of 3 (permalink) Old 10-16-2007, 06:25 PM
Re: EBP sensor question
Sometimes a bad EBP sensor won't even flash a CEL. The EBPV won't work right--but that won't be a problem for you.
Putting a substitue resistor for the sensor value in might be an easier way to go. LMK if you need the normal sensor range Eric. Hopefully somebody will chime in on pulse width with your chip.
Racer X is offline
post #3 of 3 (permalink) Old 10-16-2007, 06:50 PM
Don't EFN worry about it
Aljay's Avatar
I bought a dfuser. Problem solved.
Tuned by T Wildman
Aljay is offline
