Key-less entry lock out - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-13-2007, 04:43 AM Thread Starter
X Racer
Racer X's Avatar
My key broke off in the ignition. The end is in the lock cylinder so it's stuck in the off position. I'm on the road so i pulled the ign switch for engine starting/off. At a rest stop, I left the truck running, took the remote and locked the door with the door switch.
Does anyone have factory key-less entry that works when the engine is running? Than it starting raining
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #2 of 16 (permalink) Old 10-13-2007, 09:38 PM
Re: Key-less entry lock out
Dang that sucks Bill. What did you figure out?
gregrob is offline
post #3 of 16 (permalink) Old 10-14-2007, 02:51 AM
OBS junkie
Cat_Rebel's Avatar
Well, did you get it figgured out yet? Might be worth it to carry a spare key.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 16 (permalink) Old 10-14-2007, 04:07 AM Thread Starter
X Racer
Racer X's Avatar
An allen wrench and a coat hanger can get you in . I'm home.
Factory Keyless remotes don't work with IGN on in 95 or 96 trucks.
Racer X is offline
post #5 of 16 (permalink) Old 10-14-2007, 04:56 AM
txpsdcrwchf's Avatar
Send a message via Yahoo to txpsdcrwchf
it doesnt work in the 99 either, but it does work in the 05. so somewhere between the two it was changed
Jeff
HIS: EARLY '99 F250 SD 4x4 Off Road, 7.3L PSD 6 SPD SuperCab Short Bed
DP Tuned (F5) NS, S, 40T, 80E,
HPx Line-DIY Tymar-Fuel System(on Return)
HERS: '99 DODGE Ram 2500 4x4 5.9l I6 Cummins 6SPD QuadCab Shortbed
Edge ez 20, 40, 60:
txpsdcrwchf is offline
post #6 of 16 (permalink) Old 10-14-2007, 07:36 AM
I've been meaning to add that fix to the list of things to be figured out and fixed. I'll let yall know as soon as i have it figured out and tested.
TimMiller is offline
post #7 of 16 (permalink) Old 10-15-2007, 05:33 PM
OBS junkie
Cat_Rebel's Avatar
Who makes a good keyless entry for the OBS trucks? I haven't seen a stock keyless entry for one yet. I guess around here they either wore out or the former owners lost them.
RIP Will Iott
post #8 of 16 (permalink) Old 10-15-2007, 05:56 PM Thread Starter
X Racer
Racer X's Avatar
Thanks, now I can warn a friend.
Lessons of the road: If you travel North in Oct, don't wear shorts! If you get a cell call always pull off the road into a business or store. Police checking you out for stopping on the shoulder get nervous when they see the ignition pulled . Put the hide a key or entry tools in place before you leave--don't count on the remote.
You can get an ign cylinder out in the off posistion without drilling. Drilling is much faster! Once you do, the steering wheel unlocks. A long flat blade screw driver can be used to start and turn Ign off. If there is no need to save the cylinder, a hand tools can get you going without an ign key.
Racer X is offline
post #9 of 16 (permalink) Old 10-15-2007, 07:05 PM
Transfer Student from TDS
w4racing's Avatar
Been in your shoes, was heading to my lake house, stopped at rest stop put my turbo timer on and forgot to turn the key back, locked the doors but had an external keypad. Truck timer ran out and the truck kept running with door locked making the keypad non usable. Some truckers loaned me some tools and I broke the tab on the rear sliding window, Worst day ever!!!
Early 99-F250 Quad Cab LB 4x4 - Banks 3.5" exhaust, fuel tank mods, Tricumulator Spings, Pyro Gauge, Banks Big Head, Tru-cool, AirDog.
w4racing is offline
post #10 of 16 (permalink) Old 10-15-2007, 09:54 PM
OBS junkie
Cat_Rebel's Avatar
I left my keys in the ignition on my old F150 once & of all places Auto Zone. If I had been down at one of the inner city ones I'm sure they would have showed me how to get in! I was mad enough to break out a window, luckly my Ma had a spare key so I called her & had to wait about 45min. But at least I didn't have to break a window. So now I have a system, keys in hand.....then lock the door!
RIP Will Iott
