Fuel Gauge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-09-2007, 10:45 AM Thread Starter
Fuel Gauge
First post and it's a question, Hope that's OK. I have a 96 F350 CC and if the fuel gauge does not have power, the needle sits right on "E", when it gets power (key on), it goes Below "E"? I have checked the connections and cleaned them and used dielectric grease on the connections. I have also checked the harness to the firewall but I'm not sure I'm heading in the right direction. I have the new brass floats, but I figured I would check around before. Thanks.
brokexj is offline
post #2 of 4 (permalink) Old 10-11-2007, 05:47 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: Fuel Gauge
You have a dead short to ground on the wire from the sensor to the gauge. That will make the needle move mast the normal position.
A pure open circuit on the sensor will make it go waaaaaayy past full. I've got a pic in my album somewhere.
Go ARMY!
cowboy_dan is offline
post #3 of 4 (permalink) Old 10-12-2007, 04:27 AM
All done now
Arisley's Avatar
Re: Fuel Gauge
Either that or the gauge is hooked up backwards.
Arisley is offline
post #4 of 4 (permalink) Old 10-13-2007, 05:07 AM
X Racer
Racer X's Avatar
Re: Fuel Gauge
The sender wire is connected to ground somewhere. It won't burn the wire because the sender reduces the voltage enough. Backwards coud be fuel + to panel ground. Has the instrument panel connector been rewired?
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
