Rear window replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-09-2007, 12:35 AM Thread Starter
OBS junkie
Cat_Rebel's Avatar
Okay guys, I never use my sliding rear window & since I mounted up the stacks the rattle is driving me nuts. I've used about half a tube of silicone & that solved the problem for about a week before that started to rattle loose. So my buddy has a one piece rear window that he'll trade. I'm just wondering what I'll need to do the swap? Do I need to go to the dealer & get a new seal? Any help would be great!
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #2 of 7 (permalink) Old 10-09-2007, 01:41 AM
Bugman's Avatar
Re: Rear window replacement
You should be able to reuse the same rubber around the window. Just be careful when you take the one piece one out. I started at a corrner and mine just poped out after that. As far as installing it it is easier for two people but one can do it. There is a trick with string but if you have never seen it it is hard to tell you how to do it. It does take a little practice. Just go easy and it should be no trouble.
Jim
Bugman is offline
post #3 of 7 (permalink) Old 10-09-2007, 04:37 PM Thread Starter
OBS junkie
Cat_Rebel's Avatar
Well, we'll give her a go & see what happens.
RIP Will Iott
post #4 of 7 (permalink) Old 10-10-2007, 02:16 AM
Local Machine Gun Builder
Kickin Y2K's Avatar
Taking the window out is prettty straight forward. Putting it back in is pretty easy too. Lube up the rubber seal, weave a piece of clothesline in the groove of the rubber seal, have someone hold the window to the cab, pull the clothesline from the inside and the lip of the seal will fold over onto the inside.
Hope I explained that well...it's easier to do than explain it
Kickin Y2K is offline
post #5 of 7 (permalink) Old 10-10-2007, 03:37 AM Thread Starter
OBS junkie
Cat_Rebel's Avatar
Well it's in now, pics up tomorrow. It wasn't too bad, atleast now I don't have to deal with that rattle anymore. Another thing that bothered me was because it was a 2 piece slider, everytime I looked in my rear view mirror I'd see this big post in the middle of my window. I drove around tonight & no rattle. The stacks seem louder, not that that bothers me too much though.
Overall I'd say it was worth it!
RIP Will Iott
post #6 of 7 (permalink) Old 10-10-2007, 05:17 AM
Don't EFN worry about it
Aljay's Avatar
Just like an old VW beatle.
Tuned by T Wildman
Aljay is offline
post #7 of 7 (permalink) Old 10-11-2007, 05:49 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Kickin Y2K
FickenSieMitDemHundNicht
Ficken?
Go ARMY!
cowboy_dan is offline
