transsmision - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-03-2007, 02:09 PM Thread Starter
transsmision
I HAVE A 1997 F-350 IT SHIFTS VERY HARD IN ALL GEARS ANY IDEAS
tired is offline
post #2 of 13 (permalink) Old 10-03-2007, 04:29 PM
Re: transsmision
What type of transmission is this? I assume you have the E4OD...correct? Is this a new problem or has it shifted this way for a long time? My transmission shifts quick and firm. But I have replaced the stock valve body so that is why it does that.
Griz
Griz is offline
post #3 of 13 (permalink) Old 10-04-2007, 12:43 AM
X Racer
Racer X's Avatar
Re: transsmision
Also, does the OD light on the shifter flash or the check engine dash light?
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #4 of 13 (permalink) Old 10-04-2007, 11:38 PM Thread Starter
Re: transsmision
yes the od light flashes no check engine light
tired is offline
post #5 of 13 (permalink) Old 10-05-2007, 12:10 AM Thread Starter
Re: transsmision
not to good with computers sorry if i sent a lot of messages to the wrong place the od light flashes but no engine light
tired is offline
post #6 of 13 (permalink) Old 10-09-2007, 03:32 AM
X Racer
Racer X's Avatar
Re: transsmision
The OD light flashing means the computer has detected a fault and set a trouble code. You'll need to have the truck scanned for the code(s). The hard shift is a fail safe mode to allow you to drive it temporarily.
Racer X is offline
post #7 of 13 (permalink) Old 10-10-2007, 10:59 PM Thread Starter
Re: transsmision
thanks i changed the tranny fluid an filter and pulled the battery cable to reset it it works fine now also i had the wrong fluid in it to
tired is offline
post #8 of 13 (permalink) Old 10-11-2007, 12:36 AM
Corona Killa
THEDIESELMAN's Avatar
Re: transsmision
that isn't good that you had the wrong fluid in it.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #9 of 13 (permalink) Old 10-18-2007, 12:53 AM Thread Starter
Re: transsmision
i know a tranny shop put in type f never go back there again
tired is offline
post #10 of 13 (permalink) Old 10-23-2007, 05:30 AM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Re: transsmision
Now I dont know anything about transmissions at all hardly. When I take off from a stop light and start to get to higher RPM's it sounds like the transmission is humming then when the RPM's drop it stops until reaching higher RPM's.
Anybody want to help on what that is?
thanks
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
