Gray Sealant? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-22-2007, 10:05 PM Thread Starter
Third Member
gtndrty's Avatar
Question Gray Sealant?
What kind of gray sealant is used on the oil pan? I found Loctite gray rtv but didn't know if it is the right stuff to use. I thought I read somewhere that it is a special Ford/Intenational sealant.
1995 F-350 CC 4X4, Auto, 3.55's, DP, No Kitty, Straight Pipe, Wildman 4 Position Chip, Gutted EBPV, Modded Turbo Pedestal, Autometer A-Pillar gauges, Tymar Open Element Intake, HPX Hose, Shimmed FPR, SP Diesel EBP Dongle, 466 Blue CPS
gtndrty is offline
post #2 of 12 (permalink) Old 09-22-2007, 10:11 PM
Corona Killa
THEDIESELMAN's Avatar
Re: Gray Sealant?
Yes it is a special ford/international sealant.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #3 of 12 (permalink) Old 09-22-2007, 11:28 PM
Taters #2 Fan
JohnDeere9610's Avatar
Send a message via AIM to JohnDeere9610 Send a message via Yahoo to JohnDeere9610
Re: Gray Sealant?
If I remenber right its a ford sealent and its good stuff
RDRCM# Five O
95 F350
Full Force stage 3 Hybrids
H2E
2L Motorsports Gen 3
Beans fuel system
Transmission by Jon Faubion
Tuned by the "WILDMAN"
99.5 Dodge
P-Pump 24v
2.6 puller
"Whitey"
JohnDeere9610 is offline
post #4 of 12 (permalink) Old 09-23-2007, 04:43 AM
<----Colin Banks
mattymx's Avatar
Re: Gray Sealant?
It is some of the best you will ever use.
mattymx is offline
post #5 of 12 (permalink) Old 09-23-2007, 04:27 PM Thread Starter
Third Member
gtndrty's Avatar
Re: Gray Sealant?
I called my local International dealer and the parts guy said he didn't know of any special sealant. So it must be a Ford thing.
gtndrty is offline
post #6 of 12 (permalink) Old 09-23-2007, 04:56 PM
South Atlanta white trash
Doodie's Avatar
Re: Gray Sealant?
Do not use anything else.
Garmon's Diesel Performance
SOLD...
01' F250 CC 7.3
16.5:1, Mahle's .0050 with harden forged, 37 deg. valve job, Comp 910's, 4130 pushrods, Mac/K&N
H-11 studs, HT turbo, DP tuned, Bean's injectors/plentums, DI's fuel system
Built trans with Red Altos/PI triple disc.
2010 CC 6.4, 6" lift, 20's & 35's
Doodie is offline
post #7 of 12 (permalink) Old 09-23-2007, 06:14 PM
morepower02's Avatar
Re: Gray Sealant?
You can get it from a Ford dealer. If I remember correct it comes in caulk gun tubes.
morepower02 is offline
post #8 of 12 (permalink) Old 09-23-2007, 06:32 PM
OEM Moderator
Tom S's Avatar
Re: Gray Sealant?
RTV Silicone Sealer (special sealant for powerstroke)
(Ford) F5TZ-19G204-AB (5oz, 1/2 caulk tube)
(Wacker) T-442
(Internatioal) 1830858C1
Tom
Tom S is offline
post #9 of 12 (permalink) Old 09-23-2007, 07:48 PM Thread Starter
Third Member
gtndrty's Avatar
Re: Gray Sealant?
Thanks Tom, that's what I needed.
gtndrty is offline
post #10 of 12 (permalink) Old 09-24-2007, 07:58 AM
Terminator Nation
Re: Gray Sealant?
Engine Sealant Goop
Motorcraft TA-31 F5TZ-19G204-AB
Intake Plenum Goop:
Motorcraft TA-30 F7AZ-191554-EA
Both come in 1/2 sized caulking gun tubes and fit standard caulking guns. 1/2 of a tube is more than enough to do two intake plenums. Make sure surfaces are throughly degreased before applying. Both sealants are great stuff.
old man dave is offline
