is this normal temp??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-12-2013, 12:06 AM Thread Starter
I just drove from ga to Washington and back and my temp never rose above what the picture
shows. What is normal operating temp?
yellowbug is offline
post #2 of 11 (permalink) Old 02-12-2013, 12:25 AM
mandkole's Avatar
Re: is this normal temp???
that looks pretty typical with the 195F t-stat. Many guys run the 205F stat. Little more heat is good, and the gauge moves a tad further.
Ford has played lots of games with gauge sweep and its mostly to keep drivers from worry. I've got a gasser gauge in mine (no resistor) and it moves to halfway or a tad over if its real warm. The thing I like is that it sweeps faster when warming up.
Bottom line is that regardless what it says, after you've driven with it enough, you know when its not right.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #3 of 11 (permalink) Old 02-12-2013, 01:16 AM
cheysays7.3!'s Avatar
I have the 205* and it never rises above the "o" in normal.
cheysays7.3! is offline
post #4 of 11 (permalink) Old 02-12-2013, 02:57 AM
theoldgirl1990's Avatar
Mine sits right below the N all day long. Looks a hair under, but looks pretty darn close.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
post #5 of 11 (permalink) Old 02-12-2013, 06:03 AM
I have the 205 t-stat as well, my gauge points straight up once warm.
97 F350 CCLB 4X4 DIY Stage I's, Beans D66 Turbo, SD CAC, Tymar Filter, T-500 HPOP
JMCX is offline
post #6 of 11 (permalink) Old 02-12-2013, 07:13 AM Thread Starter
Very inconsistent
post #7 of 11 (permalink) Old 02-12-2013, 03:31 PM
Mine sits right between the "N" and the "O" in NORMAL. If you really want to know what's going on with the water temp, you need to get an actual water temp gauge that's accurate.
Something to think about... how old is your thermostat? I recently replaced mine because the gauge wasn't even moving off the bottom marks. It was stuck open and not holding any coolant back at all, never allowing the truck to heat up to operating temp.
NotMatt is offline
post #8 of 11 (permalink) Old 02-12-2013, 04:03 PM
jeremiahmercier's Avatar
What he said, mine reads exactly the same!
-06 CCLB 6.0, studs, heads reworked, studs, dummy plugs, stand pipe, updated stc fitting, egr delete, 6.4 banjos, blue spring, New oil cooler, 40 FICM, stage 1 powermax, and Looney Wild, 4 inch exhaust
SOLD-1996 f250 4x4, ZF5 with BASB and 175/100s
-2002 F250 4x4, auto, ECLB, CAI, CCV mod, Dp-Tuner, air heater delete, 4"dp, billet 38R
jeremiahmercier is offline
post #9 of 11 (permalink) Old 02-12-2013, 04:04 PM
With a water temp gauge mine struggles to get to 180deg. On the dash its just past the "N" 203 degree t-stat is in order
Tow rig - 1996 F-250 now a 350 7.3, 6637 intake, 3in dp, 4in straight pipe exhaust, 6 pos with PHP tunes, intercooler, gauges.
Wheeling rig - 1995 Jeep Wrangler, 4.0 turbo, spring over, Dana 60's, spooled rear locked front, 37's, full cage.
f250towrig is offline
post #10 of 11 (permalink) Old 02-14-2013, 10:44 PM
im going with this one^^^^
97 ccsb 4x4. Tymar custom intake, 1.0 housing, turbo blanket, mbrp 4 in exhaust 3 in downpipe, kingpin d60 rsk, ccv mod, swamps idm mod, beans e-fuel, upgraded banjo bolts, 203* thermostat, bts valve body, external trans filter, 45k lb trans-cooler, glowshift gauges, 6 position bully dog chip, superduty-lariat seats....
Dundunitall is offline
