dash cluster question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-11-2013, 04:03 PM Thread Starter
Is the milage of the obs trucks stored in the dash cluster or in the pcm and the dash is just used as a display. If I were to chance the cluster would it read my milage of the milage of the used cluster?
Tow rig - 1996 F-250 now a 350 7.3, 6637 intake, 3in dp, 4in straight pipe exhaust, 6 pos with PHP tunes, intercooler, gauges.
Wheeling rig - 1995 Jeep Wrangler, 4.0 turbo, spring over, Dana 60's, spooled rear locked front, 37's, full cage.
f250towrig is offline
post #2 of 8 (permalink) Old 02-11-2013, 04:06 PM
Re: dash cluster question
Its behind the speedometer. If you put another speedo in it it will read that mileage not your current one, but you can switch the "memory chip' on them
97 f250 eclb e4od 4x4: p.i.s. 175/80s, built trans, obs/e99 hybrid turbo, t500, .20 over, afe intake, afe 4" straight pipe, comp springs, efuel, sd intercooler, isspro gauges, superchip 1705 because I can't decide between tony wild man or gear head for tunes....
blacksmoke powerstroke is offline
post #3 of 8 (permalink) Old 02-11-2013, 06:19 PM Thread Starter
ok thinkin about getting a spare to send to you. use the truck alot.
post #4 of 8 (permalink) Old 02-11-2013, 07:13 PM
Ok let me know
post #5 of 8 (permalink) Old 02-11-2013, 07:44 PM
deezeljunky's Avatar
Is there a thread anywhere for swapping out the "memory chip?" VERY interested....
deezeljunky is offline
post #6 of 8 (permalink) Old 02-11-2013, 08:18 PM
Nothing to it its 3 torx screws holding it on back of the speedo
post #7 of 8 (permalink) Old 02-11-2013, 08:28 PM
jbrixen's Avatar
are they the same as a gasser?
jbrixen is offline
post #8 of 8 (permalink) Old 02-11-2013, 09:20 PM
Yes
