97 to early 95 parts interchange? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-11-2013, 02:03 PM Thread Starter
I have a early 95powerstroke and have access to a 97powerstroke and was wondering if the engine parts would interchange? Parts I am considering-------Injectors, HPOP, IDM? Any help is appreciated.
streetrodder01 is offline
post #2 of 8 (permalink) Old 02-11-2013, 02:07 PM
jbrixen's Avatar
Re: 97 to early 95 parts interchange?
early 95 hpop will not work, late will
idm will work
iirc the injectors will work if it is not a cali truck. (unless you are using fore cores for performance injectors)
jbrixen is offline
post #3 of 8 (permalink) Old 02-12-2013, 01:10 PM Thread Starter
Do you know why the HPOP will not interchange? Im trying to understand the difference. -THANKS
post #4 of 8 (permalink) Old 02-12-2013, 01:20 PM
jbrixen's Avatar
the anti drain back on the 94.5-95 is in the pump, and the 96-03 are in the front cover. front cover and hpop res are different between the two.
jbrixen is offline
post #5 of 8 (permalink) Old 02-12-2013, 02:27 PM Thread Starter
I see. THANKS
post #6 of 8 (permalink) Old 02-13-2013, 03:36 AM
Terminator Nation
Which way do you want to swap parts?
old man dave is offline
post #7 of 8 (permalink) Old 02-13-2013, 11:55 AM Thread Starter
I want to place the 97 parts on my early 95 truck.
post #8 of 8 (permalink) Old 02-14-2013, 11:55 AM
Terminator Nation
IDM will interchange but will be same voltage, injectors will interchange if your 97 is a Federal engine, but the injectors are the same 90 cc size. HPOP probably will not interchange. Turbo is the same. Fuel pump will interchange if 97 is Federal engine. If both trucks have the same transmissions then the PCMs will interchange if 97 is Federal engine. Block/heads will interchange but the later heads have 10 bolts for the intake plenum and the early engine will have 8 bolt plenums. Intake plenums are the same design but have different amount of mounting bolts. Engine wiring harnesses will interchange if both trucks are Federal trucks.
