Fuel Pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-11-2013, 02:58 AM Thread Starter
F250HIGHBOY77's Avatar
Fuel Pressure
My rig has 345k mi on her so far. I took out my fuel press gauge and checked pressure. I was astounded to see she had 60 psi at idle! I figured it would have been weak with that many miles.
F250HIGHBOY77 is offline
post #2 of 4 (permalink) Old 02-11-2013, 04:12 AM
jeremiahmercier's Avatar
Re: Fuel Pressure
yeah, sounds great
-06 CCLB 6.0, studs, heads reworked, studs, dummy plugs, stand pipe, updated stc fitting, egr delete, 6.4 banjos, blue spring, New oil cooler, 40 FICM, stage 1 powermax, and Looney Wild, 4 inch exhaust
SOLD-1996 f250 4x4, ZF5 with BASB and 175/100s
-2002 F250 4x4, auto, ECLB, CAI, CCV mod, Dp-Tuner, air heater delete, 4"dp, billet 38R
jeremiahmercier is offline
post #3 of 4 (permalink) Old 02-11-2013, 10:33 AM
Re: Fuel Pressure
If that is the original pump, it is amazing. It would be a testiment to just how robust the mechanical fuel pump design for the OBS really is.
Airstreamer67 is offline
post #4 of 4 (permalink) Old 02-11-2013, 11:16 AM
Bleeds IH Red
6.9PoweredScout's Avatar
Re: Fuel Pressure
Mine was low with 300k, a fpr shim it stays around 60. I found a oem fuel pump on ebay for 70. Figure I'll replace that and the hoses this summer I'll be good for another 300 k.
-Jon
1980 IH Scout Terra
6.9L
1971 IH Travelette Crew Cab
DTA466 swap.
1991 F350 CCLB DWR 7.3L Banks Sidewinder/ E4OD 2WD
6.9PoweredScout is offline
