97 psd idm relay going crazy, randomly dies. Need help!!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 02-10-2013, 10:08 PM Thread Starter
Goose it
Its my father in laws truck, cant seem to locate the problem.
So far the time between shut downs is not consistant. Hooked up multiple scanners but there are no codes. The check engine light will come on. But wont pull any code.
97 f350 psd cc lb, banks chip, gauges, and 160 injectors. 332k miles
Changed so far
Cps
Alt
Glow plug relay
Tested hpop checked out fine
Right before it dies it will get a drain on the batteries. Which i think its going to low for the pcm and it shuts down, cant seem to find out where the draw is comming from.
Im at a loss and he wants to sell his truck now.. Any help would be appreciated.
Read hundreds of forums on it, but so far none are helpful. I know every problem can be different.
We have also took out the chip and tried it stock with a no go.
Relentless is offline
post #2 of 22 (permalink) Old 02-10-2013, 10:14 PM
K Kinas
Re: 97 psd idm relay going crazy, randomly dies. Need help!!!!
Does it die with a battery charger on it?
PistonPin is offline
post #3 of 22 (permalink) Old 02-10-2013, 10:33 PM Thread Starter
Goose it
Ya, and we used the batteries out of mine as well
post #4 of 22 (permalink) Old 02-10-2013, 11:11 PM
jeremiahmercier's Avatar
maybe the pcm itself? Do you also have a Powerstroke?
-06 CCLB 6.0, studs, heads reworked, studs, dummy plugs, stand pipe, updated stc fitting, egr delete, 6.4 banjos, blue spring, New oil cooler, 40 FICM, stage 1 powermax, and Looney Wild, 4 inch exhaust
SOLD-1996 f250 4x4, ZF5 with BASB and 175/100s
-2002 F250 4x4, auto, ECLB, CAI, CCV mod, Dp-Tuner, air heater delete, 4"dp, billet 38R
jeremiahmercier is offline
post #5 of 22 (permalink) Old 02-10-2013, 11:20 PM
mandkole's Avatar
IIRC, idm relay clicks when there is key power and the #6 fuse is pulled. (I noticed this after following Bean's instructions during injector change when purging the fuel/oil from the cylinders.) The line that the #6 is on seems to be the one losing power. Why its losing power, I cant say but hopefully this directs the troubleshooting effort.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #6 of 22 (permalink) Old 02-10-2013, 11:50 PM Thread Starter
Goose it
I also have a powerstroke, just a little leary to putting my pcm in it incase something in his truck fried his
post #7 of 22 (permalink) Old 02-11-2013, 12:06 AM
ok, than try swapping the idm, only takes 5 min.
post #8 of 22 (permalink) Old 02-11-2013, 12:22 AM Thread Starter
Goose it
I will give it a try. Thanks ill post back when i can get time to try it
post #9 of 22 (permalink) Old 02-12-2013, 04:25 AM Thread Starter
Goose it
Swapped the idm, ran great, bust still died 2 times, plugged his back in, now his wont start. Works fine with mine. Ugh
post #10 of 22 (permalink) Old 02-12-2013, 03:48 PM
I DONT KNOW, but maybe his idm killed his pcm. Maybe you could try using your idm and pcm, if your idm ran better, i would think this could be the problem, just a suggestion though
